Brush hogging????
/ Brush hogging???? #1
s1120
Columbia county NY
87 Ingersoll 444, 84 Ingersoll224/'44 GreavlyL/60'sGreavlyL/49 Ford 8N
Well, I keep thinking what I want to do about brush hogging my land. I got 4.3 acres of land, and a little less then half is woods. My first problem is I don’t have a ton of money to spend. My second is that I have a lot of poison ivy in the woods, and sence I have it for a second time this year,/w3tcompact/icons/frown.gif I want to stay away from it as much as possible. My first choice is paying someone to do it. OK, ya it makes sense, but I want the fun./w3tcompact/icons/smile.gif. Or I can rent one. That would be a lot of money, and I would have to set aside a whole weekend to do it. I would like to do it a bit at a time when I feel like playing. Also I would have to redo this a few time a year. A PITA. I could also get one of those walk behind brushcutters,like a DR, or a billygoat. It would take longer, but I don’t have a ton to do. Big problem with that is I would think all the chopping would blow all over me.[back to the poison ivy thing] Any one have one? Does that happen? Best part about this is the price. For about $1500 I’m set. I was also thinking of one of the tow behind cutters that they make now. A little more then walk behind but gets me out of the spray, and I can use the tractor I have now to pull it. Problem with that is they say it will cut up to 1.5in thick stuff. How true is this, and can parts be gotten if I brake something? Last choice a real tractor. Problem is $$$. I am looking at spending at least 3grand, and then get a 3 point brush hog. Good points? Come on, it’s a tractor./w3tcompact/icons/smile.gif Can use other attachments.[post hole digger can come in handy] And can use a loader.[may not be able to swing it at first, but down the road] One question with this? Does a tractor mounted brush hog throw clippings all over you.[back to the poison ivy]? Any thing I’m missing? Any input? Thanks.
/ Brush hogging???? #2
If your primary concern is getting poison ivy stems, etc spraying on you from the brush hog, a simply solution may be to (a) buy what you want, and (b) the first time you knock it all back, do it on a cool day and wear clothes that will cover all of your skin (long sleeves, long pants).
/ Brush hogging????
I would not say its primary, but just something to think about.[as I sit here iching like crazy] Any thing I chose I will be all bundled up, if not for the PI, for all the ticks in the woods.
/ Brush hogging???? #4
I understand about the seat time,but if you think the poision ivy might affect your health I would hire someone to chop it couple of times,and if you decide to do it yourself wear heavy clothes and glove plus mouth protection,and try and void a breezy day.
The best setup for brush hogging I've seen 8N Ford w/a brush hog..those little beast can go about anywhere,and out shine some 4wd tractors<---bet I'll pay for that statement. /w3tcompact/icons/wink.gif
/ Brush hogging????
<font color=red>bet I'll pay for that statement</font color=red>
Not from me. /w3tcompact/icons/smile.gif I would love to get and old 8n, or a old ferggy. I perfer gear drive, and I am a good size guy, so power steering is not a big thing. I have seen loaders on them before, so they would be doable. Plus they fit into my price range./w3tcompact/icons/smile.gif
/ Brush hogging???? #6
Thomas:
Rember away back when some of them tractors had an idler wheel and track for rough going.
Egon
/ Brush hogging???? #7
During the winter months, poison ivy is much easier to work with (no sap). Once you get it cut back, it's one of the easiest plants to control with 24D. The birds will continually reseed for you, so it's an annual task (spraying). Ted
/ Brush hogging???? #8
Belt guards in front will reduce the amount of contact you have, but I'm afraid dense and tall ivy particals will still find their way to your skin, or worse still, down your throat if you are very sensitive.
If you need to do it yourself, the best solution to avoiding all contact is front and rear belt guards, a damp day, and a cab with fresh air supply filters. If you have only minor sensitivity, such drastic measures may not be needed.
/ Brush hogging???? #9
Paul, I own a DR Brush Cutter. It is the 14 horsepower model, and I have had it for two years, with aprx 400 hours on it. I have only broken 1 part, it was under warranty, and was promptly shipped from Country Home Products, other than that, a tune up and replaced a belt once. Great company to work with, I have had excellent customer service. I own 17 acres but only maintain about 5 with it, combination of woods and pasture. The material comes out the right side of the machine, and I have not had any trouble with material blowing around. If you are worried about it, do the work on a cool day after a rain. Their add says it will cut 1" material, but I can cut anything I can knock over, and have cut 2" material before but they were "softer" young trees or scrub brush. I also rented the Billygoat brand, which was built like a tank, but the way it shifted was hard, and after 8 hours I could not even shift it any longer. It also had tractor stlye tires, and would spin when trying to climb over logs. The DR has more of a studded turf tire and it has more surface area and gets better traction.
Next year is my target for a tractor, and I see the DR as a nice companion. I will always keep it. It is so easy getting in the woods and working small areas. I also like to clean an area up before trying to get a tractor in it, so I know what I am driving on/in/over.
/ Brush hogging???? #10
Kinda Egon..but if I say yes I will telling my age. /w3tcompact/icons/wink.gif
/ Brush hogging???? #12
I would think a tow behind unit with its own power source would be OK. It should leave the stuff behind you and you already own the tow unit.
From my own experience with my Power Trac with the brush hog out in front with a front discharge; I was surprised how little stuff came back on me. However, when I cleaned the tractor, there was lots of stuff to remove off of the front and that is where I would have caught the itchy stuff. But I didn't even though I mowed lots of poison ivy.
With my IH2500b the brush hog was a 5' 3pt unit. I never got stuff on me from the cutter, just had to drive through the stuff to get it to the cutter, or spend the day backing into everything with my neck strained. That's what I didn't like about the rear mount cutter and what drove me to the PT.
/ Brush hogging???? #13
OK, Paul!! I'm glad Thomas brought up the 8N!! Of course he's right!! The best machine for brush hogging is an 8N or a Feguson. You can get one pretty cheap in our area, neighbor!! Pick up the Want Ad Digest!! That's where I got my Fergy!!
/ Brush hogging????
Rich,
Went to look at a 9n yesterday. Wanted WAY to much for it. $2500 for a real tired, brush painted tractor. $1500 and I would have talked to him. I don't mind tired, but I am not going to pay a ton for it./w3tcompact/icons/smile.gif[ya, OK, I'm cheap/w3tcompact/icons/smile.gif]
/ Brush hogging????
I'm looking. I would like to get a old Fergie like yours. You get the look of the old Fords, but a little more advanced. They do seem to run about 2grand more then the Fords though.
/ Brush hogging???? #17
Paul, I got my Fergie almost 2 years ago from an ad in the Want Ad Digest for $3200, with a 5' 3ph snow blower. I haven't picked up a WAD in a couple of weeks, but there were a few Fergies in there about 2 weeks ago. I'll keep a lookout for one for you!
/ Brush hogging???? #18
Maybe you can tell by my handle that I am partial to old Fords. I have an 8N that I acquired about 18 months ago for $2500 - that included a pretty good 5 ft. brush hog. It was rebuilt with a recent paint job, but not truly restored. I prefer the 8N over the 9N or 2N since it has draft control and 4 speeds versus 3 speeds. They are easy to work on, and I am amazed at what the hog will shred. I have 18 acres of woods with about a half mile of roads running through that I maintain with it. I have a lot of poison ivy that I run over and have never been bothered by it when hoggin', even though I am fairly sensitive to it otherwise. If you get one, be sure to get the overrunning coupler so it won't push you into a tree or fence. Best money I ever spent, but I still want a little orange tractor with FEL.
/ Brush hogging???? #19
In my business we deal with Poison Ivy some. I go to the local drug store and buy a cream that keeps the poison Ivy off you. Its kinda like a sunblock but its Ivyblock.
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2014 FREIGHTLINER BUSINESS CLASS M2 106 (A62613)
2014 FREIGHTLINER...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
John Deere 425 Riding Mower (A66408)
John Deere 425...
