Brush Hog Secrets
/ Brush Hog Secrets #1
mowingcorey
West-Central Indiana
Yanmar 1401D
I first ask about tilling secrets - thanks for everyone's help and advice. Now, what about brush hogging. I have a 4ft Howse cutter. Not having a live PTO, letting off the clutch with the PTO engaged seems to put a lot of strain on the tractor, for my tires and blades are starting at the same time. At what engine RPM speed should I start at? Any other advice would be much appreciated. Thanks.
/ Brush Hog Secrets #2
You need to get an over-run coupler when using the bush hog. When you press the clutch in the tractor will stop and the bush hog will wind down without pushing the tractor.
/ Brush Hog Secrets #3
" At what engine RPM speed should I start at? Any other advice would be much appreciated. Thanks"
Slow, the same rpm as if you didn't have the brushhog.
/ Brush Hog Secrets #4
The direction you mow is important. My brain fuzz's up after a few months of not doing something, but I believe you need to keep the unmowed grass on your left side for better mowing do to the rotation of the blades.
/ Brush Hog Secrets #5
I find that it is easier cutting with my 1500D if I start the cutter with the transmission in neutral and wind it up a bit before moving the tractor. That way the blades are up to cutting speed when I start.
My cutter is a JD 413. The operator's manual recommends operating with the uncut portion on the right hand side. That is to allow grass knocked down by the tractor tires on the previous pass to be picked up and cut. This is for counter-clockwise rotation (looking down) of the blades. If yours turns the other direction, I would assume you should go the other way.
/ Brush Hog Secrets #6
I've got the 513. I just know I always did it wrong till I read the owners manual. Been a long time since mowing season last year.
/ Brush Hog Secrets #7
This is common for us ford 8n owners.. Get an orc.. then le tthe mower spin up at low rpm, in neutral, then increase rpm to mowing rpm... then clutch and get into gear.. slip clutch and start mowing..
Soundguy
2015 Nissan Altima SV Sedan (A61574)
2015 Nissan Altima...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
17394SFL (A61568)
17394SFL (A61568)
International S1900 (A63689)
International...
