Brush hog rebuild.
   / Brush hog rebuild. #1
SNUFFY 1944
mo
kubota L2500
Want to rebuild a bush hog side panels. My question is can the side panels be straight? Is there a reason that the side panels always curve toward the back? Figured may be something to do with the cutting action of the blades. Would be a lot easier if they could be straight.:newhere:
   / Brush hog rebuild. #2
Older rotary cutters had square decks. Then the rear corners were cut at 45 degrees to save on steel. now most are rounded. Build it however you want and are best able to do.
   / Brush hog rebuild. #3
The angle or rounded backend lets you get closer to objects on a turn.
UNUSED INDUSTRIAS AMERICA F08 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
KUBOTA SVL97-2 SKID STEER (A51246)
KUBOTA SVL97-2...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
