Brush Hog mods
/ Brush Hog mods #131
Hopefully the shaft isn't scored too, or you will have a bigger problem.
/ Brush Hog mods
We started installing a simple driveline seal. Pretty certain this thing has never been apart and rarely greased...making matters worse. U joint was a heck of a fight, so was the yoke and shaft. Everything went into the press ultimately.
Heavy and rusted - not fun. U joint clips rusted to death... broke when disturbed...have to find them now.
The shaft looked good and the seal was a good fit.
Weird U joints had no roller bearings by design. Cleared the grease passages of old hardened grease. Will try to find time to put it back together today - we'll see.
/ Brush Hog mods #133
it’s only been 62 days. After the Body shop and paint, under lighting, touch up paint, assembling a video production crew, a couple of young actresses (+ stunt doubles), and the red carpet premiere, TBN release date is probably looking at spring of 2024 :rolleyes:
But it will be a fantastic video!
  • Good Post
Reactions: D&D
/ Brush Hog mods
It works !
Will upload some pics here in minute
/ Brush Hog mods
Chain mower test.
Before and after
/ Brush Hog mods
Here she is in all her glory.
/ Brush Hog mods
It cut weeds, small trees, and broke rocks. Seemed to run best about 480-500 rpms ( I'm guessing) There was some unwanted vibration at full 540 rpm per my rpm indicator. So backing off a bit gave the same cut and mulch without so much vibration. The good news is there are no leaks! That seal was a biotch to replace.
She is a very solid tool. I dare the weeds to grow :LOL:
I'm using 70 grade 3/8th chain which did not show alot of wear in our little test. I think the harder the better on the chain. Nothing flew out the front so the curtain is working as designed. I may have had the mower a little low.
All in all we're happy so far.
/ Brush Hog mods #138
Good Morning scootr,
Glad its working out for you ! Looks awfully dry out there, maybe you should bring it up to Vermont and see how it works on our really lush and green fields !;):)
Anyway good to see you managed to fix all the problems with this unit ! Wondering how thick of a shim or gasket you had to use to get the proper backlash on your gears ?
Now that its working properly, you can paint it up pretty to match your tractor !;)
/ Brush Hog mods #140
I admire your persistence. Do you think you need to add some mesh to the ROPs? The ROW mower guys used to do that around here.
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A59231)
2018 Regal 29OBX...
Lone Star dump trailer (A55973)
Lone Star dump...
