Brush grubber
   / Brush grubber #11
Run the chain over a tire wheel rim to change forward motion of tractor into vertical pull on bushes.
3/8" or 5/16" chain will slip on small diameter verdure. A smaller chain will grip.
Was gonna say this. Second this.
Ralph
   / Brush grubber
I'll probably get the BG-08. It's only 12 lbs so it's not going to be a workout. The next size up they have in stock is the BG-30. At 50 lbs and over $200 I think it's beyond what I would ever need. The only chain style one they have in stock is the BG-16. The description says it's for atvs and lawn tractors so I think I would damage it before reaching the limit of my loader. I did read about a few people bending the jaw style but I'm thinking they were probably yanking on it vs just pulling. Also some people were saying the chain style ones would have the chains spin so the smooth side of the chain ended up against the bush and would slip. If they had the BG-11 in stock I might of went that direction but anything larger than 2" I'd use my backhoe if at this house and there's nothing of that size at the wife's house. Plus once they get that size it's just as easy to wrap a chain around them.
   / Brush grubber #13
Just thought I would add. 3 weeks ago, I purchased the BG-08 grubber. We bought property and were starting to clear out around a pond. Lots of 1-4" locust, birch, and pines mixed in with a ton of clumped brush of some kind. Wasn't sure I wanted to spend the $50, but gave it a try. After 30 minutes of me running the grubber and my wife on the tractor, we could see the pond finally. After about an hour, I couldn't believe the pile of ripped out trees we had. We started getting into the clumping brush and while it was working, the grubber had to be put on individual shoots, or I gad to dig down a bit to try to get onto the root. I chatted for 30 seconds with the wife and we both agreed we needed to buy the chain grubber. We paused for an hour, then got back to it with the chain grubber. Other than being a bigger pain to take off the trees once ripped out, it worked much better on the small stuff. For a couple of weeks we have switched back and forth, but but over all very impressed with both. We only ran into one 4" locust that I had to use the backhoe on. Everything else popped right out.
Bottom line, we got both and would do it again in a heartbeat! Great product and a huge time-saver.
   / Brush grubber #14
Which version of the chain grubber did you use?
   / Brush grubber #16
Thanks a lot, I think I will try that one. I want to pull bushes out of the water and was hoping the smaller one would work without being too small.
   / Brush grubber #17
I have the clamp style as well and it works well up to a certain size. The downside is you need a helper or it's constantly getting on/off the tractor.
   / Brush grubber
We spent about 5 hours yesterday pulling small trees next to the house and cutting down a couple large pine trees. Out of pure luck we had a 12" chipper loaned to us for the afternoon (they rented it for the day but were finished before noon) so we did more than planning to take advantage of it. Over all I would say the bush gubber worked out very well. There was 7 of us, my on the tractor, one putting the grubber on the trees, one with a chainsaw cutting off the root ball and 3 dragging the tops to one running the chipper.
The spring on it wasn't too strong and once open it was very easy to hold it open with one hand. Because there were mostly cedar trees in a hedgerow wrapping a chain around them was kind of difficult but with the grubber you reach in and get a bite. Some of them I was able to easily just raise the loader and pull them out. A few that had the roots intertwined I had to pull sideways. I think the grubber slipped off maybe 4 or 5 times on about 40 trees. On two I had to wrap the chain around them as the grubber just didn't want to get a good enough bite. Over all I'm happy with it. The others that it slipped off of I think it was still in the learning process. Common sense kind of says put the two round teeth pads on the fattest part of the tree but it seams like putting it a little deeper so once you start pulling and the teeth start to bite in you are pulling it into the meatiest part of the tree. The directions say not to jerk it, just pull. I can see how jerking it would bend it as once it bites into a tree it really bites in.
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
John Deere 6110M (A53317)
John Deere 6110M...
2007 FORD F-450 SUPER DUTY (A58214)
2007 FORD F-450...
