Brush(bush) hog connecting to the compact tractor.
   / Brush(bush) hog connecting to the compact tractor. #11
Quick hitch.... Makes life much easier....
Does it? Really? I have gotten pretty good at changing implements. Having a flat spot to do it makes all the difference and I set the larger attachments on wood blocks so I have more vertical space to line up the arms. I don’t know if the extra weight and moving the implement farther back is worth it unless you need to change attachments multiple times every day, especially on a small tractor.
   / Brush(bush) hog connecting to the compact tractor. #12
There are no true standards on 3 pt implements. Quick hitches are a modern thing and most older implement’s do not work without modifying them. That being said most modern implements are junk and the old stuff will be around forever
   / Brush(bush) hog connecting to the compact tractor. #13
When I park mine, I set the front corners on a 4x4 and the back corners on a 6x6. It makes the hook-up much faster and the 3 point quick-hitch is much easier for me.
   / Brush(bush) hog connecting to the compact tractor. #14
Pat’s Easy Change - best add on ever.
Totally agreed.
Jkk
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
2017 FORD F550 XL SERVICE TRUCK (A57192)
2017 FORD F550 XL...
2005 Autocar WXR T/A Heil 28Yd Side Loader Garbage Truck (A55852)
2005 Autocar WXR...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
FAKE (A52472)
FAKE (A52472)
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
