Brush(bush) hog connecting to the compact tractor.
   / Brush(bush) hog connecting to the compact tractor. #11
Quick hitch.... Makes life much easier....
Does it? Really? I have gotten pretty good at changing implements. Having a flat spot to do it makes all the difference and I set the larger attachments on wood blocks so I have more vertical space to line up the arms. I don’t know if the extra weight and moving the implement farther back is worth it unless you need to change attachments multiple times every day, especially on a small tractor.
   / Brush(bush) hog connecting to the compact tractor. #12
There are no true standards on 3 pt implements. Quick hitches are a modern thing and most older implement’s do not work without modifying them. That being said most modern implements are junk and the old stuff will be around forever
   / Brush(bush) hog connecting to the compact tractor. #13
When I park mine, I set the front corners on a 4x4 and the back corners on a 6x6. It makes the hook-up much faster and the 3 point quick-hitch is much easier for me.
   / Brush(bush) hog connecting to the compact tractor. #14
Pat’s Easy Change - best add on ever.
Totally agreed.
Jkk
2021 Toyota Rav4 AWD SUV (A55853)
2021 Toyota Rav4...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
