Broken weight bracket
/ Broken weight bracket #1
AceDeuce
Northern Virginia
Kubota BX1500 w/ R1's and LA181 FEL
Everyone who owns an older model BX knows about the infamous air cleaner band that is notorious for fatigue failure. Mine was replaced before 100hrs.
Well, I have a new problem and I'm wondering if anyone else has experienced something similar.
The BX1500 has a large cast iron counterweight mounted over the engine's valve cover. It is there to prevent the inline 2-cylinder diesel from shaking the tractor to pieces. Two brackets made of 1/4" thick steel plate bolted directly to the engine block hold the weight in place. One of the brackets on my machine actually snapped in half! After performing surgery to remove the pieces it was obvious fatigue failure.
Yesterday I welded the pieces back together and with luck I should have time tonight to reinstall the repaired bracket.
My question is: Has anyone else had this happen? Something similar related to engine vibration?
I was shocked. It never occured to me that heavy duty of a part would failure like that. I know that little 2-cyl shakes a lot, but it is smooth as silk just a bit off idle. Regardless, I don't think something like that should happen.
Any thoughts?
/ Broken weight bracket #2
Boy that is a tough one!!! :(
Remember if it is not broken, brake it! :cool:
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
