Broken weight bracket
/ Broken weight bracket #1
AceDeuce
Northern Virginia
Kubota BX1500 w/ R1's and LA181 FEL
Everyone who owns an older model BX knows about the infamous air cleaner band that is notorious for fatigue failure. Mine was replaced before 100hrs.
Well, I have a new problem and I'm wondering if anyone else has experienced something similar.
The BX1500 has a large cast iron counterweight mounted over the engine's valve cover. It is there to prevent the inline 2-cylinder diesel from shaking the tractor to pieces. Two brackets made of 1/4" thick steel plate bolted directly to the engine block hold the weight in place. One of the brackets on my machine actually snapped in half! After performing surgery to remove the pieces it was obvious fatigue failure.
Yesterday I welded the pieces back together and with luck I should have time tonight to reinstall the repaired bracket.
My question is: Has anyone else had this happen? Something similar related to engine vibration?
I was shocked. It never occured to me that heavy duty of a part would failure like that. I know that little 2-cyl shakes a lot, but it is smooth as silk just a bit off idle. Regardless, I don't think something like that should happen.
Any thoughts?
/ Broken weight bracket #2
Boy that is a tough one!!! :(
Remember if it is not broken, brake it! :cool:
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
New Holland 3930 (A60462)
New Holland 3930...
2014 John Deere 650K LGP Crawler Tractor Dozer (A61572)
2014 John Deere...
2005 SBX-5 60in. Box Blade Tractor Attachment (A61572)
2005 SBX-5 60in...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
