Broken Tractor...
/ Broken Tractor... #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
On my way to town this AM from the country I saw a large row crop tractor ..looked like an IH probably 100 HP or so with a disk harrow behind it disabled in the middle of a half plowed field. The left rear tire and hub had broken off - the tractor was just leaning over...had to be massive damage...I am curious how that will be serviced, I mean, it is a plowed field and there it sits...I can't see how the farmer will be able to work on it there or get a trailer to it...I feel for him.
/ Broken Tractor... #2
That will probably end up being a dealer shop service call. Lots of timbers to support the tractor while repairs are being made.
Neighbor had a similar incident a few years ago on an old 560. Only in his case one of the axle clamp bolts on the axle/hub clamp broke and let the wheel slide off the axle.
We ended up locating 25 or so railroad tie blocks about 3 feet long, and just kept jacking and blocking until the tractor was high enough to slide the whole assembly back on the axle and replaced and tightened all bolts. It ended up being an all day job, but fortunately we were in a hay field, not worked ground.
/ Broken Tractor... #5
I do in-field welding all the time on disabled tractors and brokem implements. That's what I have a 4wd long bed diesel pickup for. The gas welder/genset, compressor and tools are in the back. I can get just about anywhere, anytime.
/ Broken Tractor... #6
Our last one .
/ Broken Tractor... #7
been there mine was just a 1440.
/ Broken Tractor... #8
Ouch!
Hope that wasn't as expensive as it looks.
/ Broken Tractor... #9
Our neighbor had a late '80s C-IH tractor, about 120hp that suffered a similar fate. It sat broken in the field for months before they fixed it. On the flip side, out at my Uncles farm in IL, we were coming down a back road one evening and there was a huge tiling machine completely blocking the road with a snapped off rear wheel. This was about the biggest tiler I've ever seen, must have had about a 20' dia bucket wheel and used 66" terra tires (it was every bit as big as a Terra-Gator floater.) Anyways, came back the next morning and it was already gone! Not sure if they fixed it right there that night or somehow got it on a big lowboy and hauled it off, but I was amazed they got it out of there so quick.
For those who don't know what a tiling machine is, I've attached a pic of a small one. The one with the snapped axle was more than triple the size of this unit (and only had 4 wheels)
/ Broken Tractor... #10
Ouch!
HaHa ..probably more expensive than it looks with new spreaders,shafts,axle , bent tin work ,chaff tray and tie rod !
/ Broken Tractor... #13
My dealer sells a lot of large equipment (for this area). He has a couple of trucks set up with hydraulic booms for servicing tractors where they sit. He brought one of them to do the 100 hr service on my little B Kubota, and it was nice to have them be able to do that right here in the yard. Very clean, neat, and handy with pumps, and bulk storage for used fluids, etc.
/ Broken Tractor... #14
By the way, where the heck is the head at?:confused:
Just beside it in the picture, We took it off to drag the combine back to the yard to fix.
/ Broken Tractor... #15
They aren't called 'Barnyard Buick's' for noth'in.:D
Actually, IH pioneered the rotary though a dyed in the wool JD fan would argue.......
New Holland made the first rotary in 1975 with the TR70
/ Broken Tractor... #17
Both of them would be wrong...
Here's a bit of history...scroll down to the part about "Western Roto Thresh Combine".
The old Roto Thresh factory site is only about a quarter mile or so from my home.
http://www.wdm.ca/skteacherguide/WDMResearch/HarvestingDvpt.pdf
From that site:
The results from early testing of the prototypes during the wet fall of 1968, near St. Denis,
Saskatchewan were promising. In a 1999 interview, Barney Habicht described the first run of the
rotary protoype: Commercial production of Roto Thresh combines began in the early 1970s at a production plant in Saskatoon. Customers who purchased the machines, which sold for around $30,000 a piece, were impressed with the new technology of the Roto Thresh. Clotaire Denis of St. Denis was the first farmer to purchase a Roto Thresh in April of 1973.
From CASE IH HISTORY:
1977
International Harvester introduces the Axial-Flow rotary harvesting concept, with its 1440 and 1460 model combines. Axial-Flow technology improved threshing and grain quality and used fewer parts for easy maintenance. The company spent $56 million and one million man-hours to design, build and test the concept. Eventually every other major equipment manufacturer developed some version of the rotary combine design pioneered by International Harvester.
/ Broken Tractor... #18
I still don't know what one is, but it looks like there sure is a lot of stuff to break on one..
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
iDrive TDS-2010H...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
LOADER MOUNT HAY SPEAR (A63291)
LOADER MOUNT HAY...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
