Broken Spindle
/ Broken Spindle #1
Matt W
N.E. Tennessee
65, 3000 Ford D, Terramite T6
I just broke the left front spindle on my T5B manual steering. Anyone know if this is a Terramite only part? Sources?
Thanks .. Matt
/ Broken Spindle
Thanks TCusack, I'll for sure call them Monday. It is just a personal use machine but I still can't stand to have it broken for long.
Just wondering if it is an off the shelf part or unique to that machine. Since I have a B chassis also wondering if a C part is the same. Never found a parts manual for the T5B. If worse comes I might be able to make it being a blacksmith with a good machinist friend.
/ Broken Spindle
$287 plus shipping, Shipping is apparently an unknown until the part is ordered.
/ Broken Spindle
Part made, looks and works as good as ever. I made the whole part. If it were to do over I think I would search for the correct spindle and cut and weld it in. Northern has some trailer spindles that might work starting around $15. Just a different way to go for someone who doesn't have easy way to make the bend or machine the spindle.
/ Broken Spindle #5
Forgive the ignorance but by "spindle" we are meaning the front curved axle type piece that holds the wheel on?
/ Broken Spindle
Yes, Was a good little project. I'm not a machinist, a better description would be a blacksmith who owns a lathe.
So the bend was no problem. The lathe work wasn't hard, just more precise than an artist blacksmith normally works to. Had the material already on hand.
/ Broken Spindle #7
Any chance you could post a picture of how it looks now? Maybe a welder could pinch hit for a blacksmith?
/ Broken Spindle
Talked to another guy in my area who has broken one, so it must not be all that uncommon. If I break another one I have a torsion bar from a tank that might be about the right size.:)
The part the bearings go on is 1 inch and the rest of the shaft is 1.25".
/ Broken Spindle #9
Thanks Matt; very nice job and congratulations on a job well done; money saved, and probably help for others of us when we get there!
/ Broken Spindle #10
Just out of curisity...... how did you break it? Carrying a load or off roading it or what?
/ Broken Spindle
Actually, I had been digging with the hoe and it fell off when I turned around and took the front end weight off the loader bucket. Admittedly I have overloaded the machine, if you look back I think there might be some photos of huge rocks in the front bucket. Looking at the broken ends it showed signs of being partially broken for some time, maybe even before I got the machine. I wasn't upset it broke, I routinely overwork this little machine as most here probably do and understand things break on old tools. I was just disappointed by the price for such a simple part. However credit must be given that Terramite is still supporting at least to some degree, a machine that old.
I looked back and didn't find the photos. So here is what I'm talking about.
/ Broken Spindle
Ok, Looks like the spindle I made from scratch lasted through 5 years of abuse on my rocky ground. It broke yesterday. I took my own advise and went with the trailer spindle from Northern Tool this time. Pretty happy with the out come. 4 wheels on the ground and sitting nice again. you can see the part number in the photos if I can remember how to post them.
/ Broken Spindle #14
This is good to know... Thanks for posting the info...
/ Broken Spindle
All the positive camber must be for easier manual steering?fullsizeoutput_1242.jpeg But it complicates building the spindle.
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A67148)
2012 FORD E-350...
2014 CASE 580N BACKHOE (A65053)
2014 CASE 580N...
Ground Protection Mats (A64194)
Ground Protection...
2022 EZ-GO ELITE...
2016 Ford F-450 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2016 Ford F-450...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
