Broken Seat Bbracket
/ Broken Seat Bbracket #1
rlsmith
Bronze Member
Northern Ohio
06 BX 23, 1956 AC Little G, JD 1025R
Well my BX23 is taking a break so I can pull the broken bracket that the seat hinges on, one side broke off right at the bolt. Well it looks like not to much of a problem if all I have to remove is the floor board an if I don't have to pull the fuel tank. Ordered part for $40 and should be here tomorrow. Anything I should know before I get started?
so much for easy...have to remove the roll bar fenders and gas tank.
Well had to remove platform, drain fuel tank, removed roll bar that allowed me to raise the fuel tank and fenders enough to be able to slide the old one out and slide the new one in. 6 hours of work with minimum tools. Then while I was at it cleaned up all the levers actions and switches. Changed the oils and filters and cleaned the hst screen. Then put it back to work...rototilled two large gardens took off that and put on the BH an FEL and leveled a dirt pill.
/ Broken Seat Bbracket #4
Oh man,that's a lot of work to fix a bracket. :-( Hope that doesn't happen too often.
Sent from my iPad using TractorByNet
2020 Inifiniti Q 50 Sedan (A61569)
2020 Inifiniti Q...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
UNUSED KJ 46'X25' METAL GARAGE (A62131)
UNUSED KJ 46'X25'...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
