Broken plastic hood?
/ Broken plastic hood?
Well it's more than 500 my dealer qouted me $675 for the hood and sides he's claiming you can't buy the hood separate from the sides. He also qouted 20 bucks each for the stickers. I got some plastic epoxy today and made a make shift repair. I can live with it for now as I can't spend that for cosmetic damage. I will eventually order a new one but I first want to do some research into buying just the hood. It's on the jd parts site with it's own separate parts # so I can't understand why it wouldn't be available.
Matt T.
/ Broken plastic hood? #22
Matt, I just checked JD Parts, and it shows a price of $630 for the hood, sides etc. And, are you ready for this- $1000 for the complete hood!!! The upper hood is no longer shown as a separate part #.
If I were to fix mine, which I won't, I would have been better off to do it right away- whie the top was available by itself.
Jon
/ Broken plastic hood? #23
Trader in for an 8N with a metal hood!:D
It'll last forever with a few rebuilds!:D :D :D :D
It will also keep all that fiberglass/plastic stuff out of the landfills. You know, the stuff that dose not degrade or rust over time! :D :D :D
/ Broken plastic hood? #24
Matt, when I called about replacing hood parts on my 3520 the parts guy asked me which sections did I need, right side, left side or top. The decals on the sides are only $2.85 each. So, maybe you need to check with another dealer. I knew it was $600+..............I wasn't wanting you to feel really bad about the damage you did is why I said over $500. Sorry, I should have just layed it on you from the start.
Sincerely, Dirt
/ Broken plastic hood? #25
Is the $675 painted or is that extra on top ? With all the recycling laws now you will find a mark on the underside to indicate what sort of plastic it is , this will tell you how to repair it . Also as i'm a master of coverups , i have at times in the same situation used a Matt Black textured adhesive vinyl to cover damage . You could have a Black mat on the hood and it would look like its supposed to be there . Many cars , trucks and machinery have them . Only last week i dropped my mobile phone and broke the outer screen , a 2"X2" piece of this vinyl and it looks like it was made like it .
/ Broken plastic hood? #27
Superduper said:
Where do you get this black adhesive vinyl?
As i live in Australia it's not much good to tell you where i get it , but i did a quick Google and found a few in your neck of the woods . You can even get Carbon fibre look (probably in the correct tractor colour as well or how about some flames:D ). I'd suggest if it was of interest to GWH , he get a computer vinyl sign maker to cut a desirable shape to suit the hood via a template in the material of choice . Probably cost $40 or so . Make sure to sand the glue bead with wet and dry or it will show through .
1996 Ingersoll Rand 185 Compressor (A64047)
1996 Ingersoll...
2011 WESTERN STAR  4900 SB (A63569)
2011 WESTERN STAR...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
John Deere 4044R (A62177)
John Deere 4044R...
2012 HEIL 200BBL CRUDE TRAILER W/ PUMP (A63569)
2012 HEIL 200BBL...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
