Broken plastic hood?
/ Broken plastic hood? #1
GreatWhitehunter
Eastern CT
JD 110 TLB
Has anyone broken the hood on their 3000 series? I was loading my dump trailer today and a large rock fell out of the bucket and smashed my hood. I was wondering how much this is going to cost me. I'm so upset with myself for be so careless. I looks like it won't be to hard to replace but I'm sure it will take a few hours anyways.
Matt T.:confused:
/ Broken plastic hood? #2
What piece of hood was damaged? You will not be happy with what the replacement parts are going to cost. The side panels are around $260 and I'm thinking the top piece is over well over $500. If you are replacing the top piece don't forget to order the two long decals that cover the seam between the side panels and the top piece. You will have to drill out the old rivets and place the old side panels on the new top piece. Then rivet the old side panels onto your new top piece. Then put the new decals over the new rivets. The good news is the decals are less than $3.00 each. Sorry to hear about your mishape. You may want to consider getting a some type of spill guard welded onto the top of your bucket to keep this from happening again in the future.
Sincerely, Dirt
Dirt, it was the top of the hood. The rock was basketball size, I just was going too fast with the loader. I didn't look at how the sides were attached to the hood. I suppose I could always glue the cracked pieces back together. And order the hood when I have hundreds to spare. Have you replace your hood before? Are the rivets anything special?
Matt T.
/ Broken plastic hood? #4
Matt, no I have not replaced my hood. The only reason I know about the rivets on the side panels is I need to replace the left side panel that is cracked. It was damaged about a month ago when my tractor got hit by a Chevy Suburban when I was plowing snow on a county road. It doesn't look like the rivets are anything special. Rivet with a backup washer. It would have been nice if Deere had attached the side panels onto the top piece with another type fasener other than rivets. Then you wouldn't need to replace the decals.
You were lucky that the rock only damaged the top piece of the hood. Basketball sized rocks can do lots of damage when they roll out of your bucket.
Sincerely, Dirt
/ Broken plastic hood? #5
I have a new hood for my 4300 sitting in my basement, after my helper dropped a big chunk of ice out of the bucket. The original hood had been cracked for a few years from the same helper trying to stand on it so I didn't feel too bad----until I found the price. The new one isn't going on until I can figure out some guard system and the snow melts from our driveway....It will be a two man job to hold things lined up while the hinge bolts go in.
From what I've been able to learn plastic welding is your only hope with JD plastic.
/ Broken plastic hood? #6
If it's coloured plastic it can be welded with an electric soldering iron(dependant on type) . Use a new blade type tip or sand off any solder on a used one . Use the blade crossways to the crack to pierce the plastic but not right through . Right in front of that small depression do it again and again and so on along it's length . You will end up with a zippered effect . If you can , do the reverse side as well .Once you finish these steps use the tip on it's flat to smooth the weld from one end to the other pulling slowly as you go . As you work you will get good at it and have good results . I have never done painted plastic but it would be the same only you will need to remove the paint along the crack . Once it's finished if you dont like the look of the repair it can be filled with car bog , smoothed and painted . I have repaired major damage to my tractor fuel tanks in this manner and have never had a leak .
/ Broken plastic hood? #7
There are plastic welders for sale that look like soldering irons but actually use hot air with precise temperature control depending upon the type of plastic. I am told that the repair should be as strong as the original but without a lot of experience, I am sure that the repaired look might leave much to be desired. Automotive urethane bumpers are repaired in this manner but then again, they sand, then paint them when done. All in all, it might simply be easier to pay for the hood replacement, learn from your mistake, then move on and be done with it.
I actually thought those plastic hoods were quite durable but then again, a basketball sized rock dropped from loader height would probably do a number on a hood of any material.
The hoods are very durable. If the hood was metal it would have done alot of damage too. The cracks are in the very front and there's no missing plastic. I'm going to try and glue it. The breaks are perfect in pattern so I think I'll be able to lie with it for now. That's the one thing I don't like about the 300x loader the bucket curl in not enough when loading and too much with the loader raised.
Matt T.:(
/ Broken plastic hood? #9
Matt, just about any loader when the bucket is raised and its heaped with material the material is apt to spill over the back of the bucket and fall onto the machine. As you are raising the bucket you have to also gradually move the bucket slightly into the dump position so as to not cause it to spill material either over the back of the bucket or prematurely dump it. Some machines are equiped with self leveling buckets, but this still is not a guarentee that you will not get material over the back of the bucket if it is raised to max dump height with a heaped bucket. If you were to raise a full bucket of material on a skid steer without doing this you would soon be under a shower of rocks and dirt either in your lap or on the roof of the machine. Same goes for just about any heavy equipment loaders.A heaped bucket will spill back over the back of the bucket if you don't move the bucket slightly towards the dumped position as you raise to full dump height. As I said before if you use your tractor to load a lot of material it may be worth having someone weld a spill guard onto the top edge of your bucket. This would keep most of the material from coming over the back of the bucket. Most not all. You still have to watch and be careful.
You are saying the curl is not enough when loading the bucket and too much when in the raised position. If the curl was more when loading it would also be too much when in the max raised position and be spilling a lot more on the hood when in the max raised position. You just can't have it both ways.Thats just the way it works. You as the operator have to allow for what is not built into the machine design. Start moving your bucket into the dumped position to keep material from spilling over the back of the bucket.
Good luck on your repairs. Let us know how it goes or better yet, post some pics.
Sincerely, Dirt
/ Broken plastic hood? #10
Some plastics are repairable, and some are not, some can be fused, welded, and some cannot. Plastic welding is not commonly used on bumpers anymore, because the OEM's have switched to polypropylene and it does not respond well to this. Epoxy, and fiberglass cloth, is the most common repair process now but, it requires some tricks due to the oily nature of the plastic.
A smart, well qualified repairman could possibly attempt a repair depending on the amount and location of the damage.
Dirt, like I said in my first post it was my fault for sure. I was being careless. I also realize that more curl low means more curl when lifted. The cx loader has more curl low which would be helpful. The biggest problem with the tractor is the operator. I need not to rush when operating and not worry about how much I need to accomplish in the limited time I have. I should also mention that I rushed my battery charger for my dump trailer battery and only got half of the charge hence limiting me to only two dumps,when I needed four.
This is going to be an expensive lesson for me it seems. I hope someone can learn from my mistakes as I certainly have. However I'm quite certain I'll be making more.:eek:
/ Broken plastic hood? #12
Matt, I wasn't giving you h_ll. Just trying to point out some basic machine design common to all loaders and maybe helping soemone else avoid a busted hood or worse. Yes, getting in a hurry never pays. I have broken my share of stuff over the years. Hope your hood repairs go well.
Sincerely, Dirt
/ Broken plastic hood? #13
On my JD 970, I finally went ahead and welded a 1/4"x6"x73" plate to the top of the bucket.
The top of the hood was beginning to look like I'd left the tractor sit outside in the middle of a h___acious hail storm! I had dimples over the front end of it from rocks spilling back over the top of the bucket!
The added height to the bucket was a vast improvement and the amount of snow that I could load into the bucket was pretty impressive, too!
AKfish
/ Broken plastic hood? #14
If this were mine I would take it to someone that can do plastic welding. Then, as mentioned in the prior post, reinforce the backside with fiberglass cloth and resin. I bet that would hold.
If it couldn't be "welded" I would try to use "Twin Weld" on it carefully and then reinforce with the fiberglass.
My first choice would be to replace the hood it but if the cost is prohibitive I would give the above a chance.
/ Broken plastic hood? #15
Use fiberglass kit from auto parts store ( comes with resin, hardener and mat) on the bottom of the hood after putting the pieces back in alignment then bondo and paint on the top as needed. Probably $35.00 at the most for an effective and longlasting repair.
Paul
/ Broken plastic hood? #16
Paul
/ Broken plastic hood? #17
Paul
Having made repairs to plastic parts on hundreds of vehicles, I can tell you, it may no be that simple. Depending on what type of plastic it is made from, there are different types of adhesion promoters, cleaners, and techniques that may be required to get the materials to adhere. Painting some types of plastic can be a nightmare.
With every new model year, comes new materials and the challenges they present to repairing them.
If the products you use do adhere, they have to expand and contract with heat and cold at the same rate as the original part or the repair will not hold up.
To start with, using 3m epoxy, made for this type of repair, (if it is not fiberglass, you do not want to use fiberglass resin), your going to spend $25+ just for that.
Sure you can guess, and you can just try it. But, you may find out the hard way, this is not always a cut and dried operation.
If you can get someone to tell you what it is made from, (good luck). and post some photos of the damage, I can suggest a course of action if you desire to attempt your own repair.
I would suggest you find an experienced competent professional. Sometimes looking at the part, and sanding an area, you can get a feel for what type of plastic it is. Some are simply not repairable.
/ Broken plastic hood? #18
I know it's an expensive lesson, but you have to step back and laugh at our humility and be thankful that you were not hurt. My family gene pool isn't particularly full of coordination, and I have spilled a bucket of dirt above my head when using a Bobcat one time. Just hearing your story is enough to make me be a little more cautious the next time I raise my bucket on my 3120. Thanks for sharing.
/ Broken plastic hood? #19
GreatWhitehunter, sorry to hear about the damage to your tractor. Glad it did'nt do any damage to the engine on you. If possible a picture or two would be appreciated, so I can see what it will look like when I sooner or later drop something on the hood of my tractor. How about this, just go and buy some green colored Ducttape to hold it together, while you wait for Uncle George's $600/$1200 check and then buy the new hood. :D
I have been wondering if the plastic hoods might be safer than steel in a situation like this. Because the plastic will break and hopefully reduce the chance the rock will bounce or roll back and hit the operator. Just a thought.
/ Broken plastic hood? #20
Matt, I feel your pain. Did the same thing with my 4120.
Had the 4in1 clamped around a bunch of branches, and threw a short lenght of trunk on the top. I *did* have the load low, but needed to raise the bucket to clear some fence as I turned. Log rolls out and smashes the hood.
This happened over a year ago, and the cracks haven't spread. There aren't many stresses there I would guess.
Yeah, it pisses me off, but not enough to spend 500 bucks on a new one.
Too many other places to spend that kind of money.
I cracked the corner of my canopy also while out in the woods in zero degree temps...
Jon
18ft Gooseneck Utility Trailer (A64047)
18ft Gooseneck...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2010 CHEVY 1500 (INOPERABLE) (A63569)
2010 CHEVY 1500...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
SET OF (3) CHEMICAL HOSE REELS (A63569)
SET OF (3)...
