Broken loader arm hydraulic shaft.
   / Broken loader arm hydraulic shaft. #1
mactrade
weslaco, texas
Massey Ferguson 573, Bobcat T 650, Landpride 4188, Bobcat Root Grapple. Brushcat
I managed to break the right hydraulic shaft of my bobcat T 650 while using the root grapple. It took about nine days to get it fixed.
   / Broken loader arm hydraulic shaft. #2
Wow. that took a lot of pressure to break.
Yep was using on side of grapple too much. At least, that was what was theorized.
   / Broken loader arm hydraulic shaft. #4
Boom or bucket cylinder?
I'm thinking it was a flaw in the metal. Bending is the more common result.
boom cylinder.
I use the 82 inch grapple.
   / Broken loader arm hydraulic shaft. #8
On the wider grapples, they can provide some side twist if you catch something the wrong way. I've seen it but I've not seen a broken shaft. I've seen a lot of bent shafts. I'd be thinking poor steel.
It may be bobcat would not warranty the part. They said I hit something to hard
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
