Broken loader arm hydraulic shaft.
   / Broken loader arm hydraulic shaft. #1
mactrade
weslaco, texas
Massey Ferguson 573, Bobcat T 650, Landpride 4188, Bobcat Root Grapple. Brushcat
I managed to break the right hydraulic shaft of my bobcat T 650 while using the root grapple. It took about nine days to get it fixed.
   / Broken loader arm hydraulic shaft. #2
Wow. that took a lot of pressure to break.
Yep was using on side of grapple too much. At least, that was what was theorized.
   / Broken loader arm hydraulic shaft. #4
Boom or bucket cylinder?
I'm thinking it was a flaw in the metal. Bending is the more common result.
boom cylinder.
I use the 82 inch grapple.
   / Broken loader arm hydraulic shaft. #8
On the wider grapples, they can provide some side twist if you catch something the wrong way. I've seen it but I've not seen a broken shaft. I've seen a lot of bent shafts. I'd be thinking poor steel.
It may be bobcat would not warranty the part. They said I hit something to hard
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
2018 Toyota Tacoma Crew Cab Pickup Truck (A51692)
2018 Toyota Tacoma...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2009-2014 Ford F150 Pickup Bed  (A52384)
2009-2014 Ford...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
