Backhoe Broken Joystick after 10 Hours (GC1725M/CB65)
   / Broken Joystick after 10 Hours (GC1725M/CB65) #61
Hopefully the newly designed AGCO part does the trick, but I did finally find someone making replacements out of aluminum. If you're no longer in warranty these seem like a much better bet.
   / Broken Joystick after 10 Hours (GC1725M/CB65) #62
This was an unheard of problem for the previous generation of GC tractor. The backhoe numbering has not changed as the CB65 name continues, but it's obvious the redesign was not better.
Hopefully AGCO address this and maybe goes back to a proven design.
   / Broken Joystick after 10 Hours (GC1725M/CB65) #63
The new BH2720 has addressed this issue
   / Broken Joystick after 10 Hours (GC1725M/CB65) #64
Is that price for 2 plates?
   / Broken Joystick after 10 Hours (GC1725M/CB65) #65
My turn.....thanks whoever posted the PN above! Luckily mine still works, just floppy.
   / Broken Joystick after 10 Hours (GC1725M/CB65) #66
Floppyness is usually caused by the nut coming loose underneath the lever plate. It's threaded on the bottom of the piece that holds the stud for the control stick heim joint. I had to fix mine. It failed the first real time I used my backhoe. I have a 2018.
   / Broken Joystick after 10 Hours (GC1725M/CB65) #67
Is that nut under the pivot plate that we are talking about in this thread?
Mine does look different then the broken ones, all three posts that come up through the pivot plate are round?
   / Broken Joystick after 10 Hours (GC1725M/CB65) #68
Thoughts, loose or broke?
   / Broken Joystick after 10 Hours (GC1725M/CB65) #69
Figured it out, just loose
40' CONTAINER (A51248)
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
UNUSED CFG INDUSTRIAL M-DRG MINI DIGGER (A51248)
UNUSED CFG...
36'' Mini Excavator Bucket (A51573)
36'' Mini...
WOODS TBW15.40 LOT NUMBER 239 (A53084)
WOODS TBW15.40 LOT...
TAKEUCHI TS80R2 SKID STEER (A51246)
TAKEUCHI TS80R2...
