broken hydraulic filter fitting
/ broken hydraulic filter fitting #1
pricevilleman
Priceville,ON
Kioti DK25HST
I removed the hoe from my CK25HST today and caught the bottom hydraulic filter. The filter came off with about 1 inch of thread from the fitting. Is this a nipple that can be replace or does the whole fitting have to be replaced. What is the best way to do it?
/ broken hydraulic filter fitting #2
I think the whole thing has to be replaced. Many here have ripped them off while grubbing which there is so much interest in a belly pan.
You are right MotorSeven. I got it off, 2 screws hold the housing to a bracket. 1 flow bolt, and 2 pressed ends with O-rings. A machine shop could put a new nipple in but the complete housing is $65.00 and shop time would probably eat it up. The biggest expense will be replacing the Hydra-Tranny fluid. Cheers!
/ broken hydraulic filter fitting #4
Hope you ordered two of them because i snapped mine off the ck20 today . How long till the new one comes in ? I may try to J B weld mine till i get a replacement . Definetly going to fab a skid plate asap
I have a Kioti dealer 20 miles away. They have a stock order every week and I was lucky to catch it. If I can't wait a week they would get it UPS in 2 days (of course the freight would be $50-60). Good idea to get 2 and get serious about skid plate. If the filter was 3" shorter a lot of our problems would go away. Cheers!
/ broken hydraulic filter fitting #6
Come spring time, I aim to fab a belly pan.....already have the cardboard stashed for a template.
/ broken hydraulic filter fitting #8
I made an adapter to join the filter to the housing. It has a weak spot so it will break off instead of harming the housing. I made an extra adapter so of course it will never break again.
/ broken hydraulic filter fitting #9
I need this!!! What tractor do u have?? Do they actually sell this for repair?? I have a Mahindra emax
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
213105 (A64276)
213105 (A64276)
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
Caterpillar 910 Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 910...
