broken hydraulic filter fitting
/ broken hydraulic filter fitting #1
pricevilleman
Priceville,ON
Kioti DK25HST
I removed the hoe from my CK25HST today and caught the bottom hydraulic filter. The filter came off with about 1 inch of thread from the fitting. Is this a nipple that can be replace or does the whole fitting have to be replaced. What is the best way to do it?
/ broken hydraulic filter fitting #2
I think the whole thing has to be replaced. Many here have ripped them off while grubbing which there is so much interest in a belly pan.
You are right MotorSeven. I got it off, 2 screws hold the housing to a bracket. 1 flow bolt, and 2 pressed ends with O-rings. A machine shop could put a new nipple in but the complete housing is $65.00 and shop time would probably eat it up. The biggest expense will be replacing the Hydra-Tranny fluid. Cheers!
/ broken hydraulic filter fitting #4
Hope you ordered two of them because i snapped mine off the ck20 today . How long till the new one comes in ? I may try to J B weld mine till i get a replacement . Definetly going to fab a skid plate asap
I have a Kioti dealer 20 miles away. They have a stock order every week and I was lucky to catch it. If I can't wait a week they would get it UPS in 2 days (of course the freight would be $50-60). Good idea to get 2 and get serious about skid plate. If the filter was 3" shorter a lot of our problems would go away. Cheers!
/ broken hydraulic filter fitting #6
Come spring time, I aim to fab a belly pan.....already have the cardboard stashed for a template.
/ broken hydraulic filter fitting #8
I made an adapter to join the filter to the housing. It has a weak spot so it will break off instead of harming the housing. I made an extra adapter so of course it will never break again.
/ broken hydraulic filter fitting #9
I need this!!! What tractor do u have?? Do they actually sell this for repair?? I have a Mahindra emax
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2024 GMC Yukon AT4 4x4 SUV (A61574)
2024 GMC Yukon AT4...
2022 CASE TV450B SKID STEER (A64279)
2022 CASE TV450B...
PLEASE READ (A63117)
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
