Oil & Fuel Broken Fuel Neck
/ Broken Fuel Neck #1
MMG
Branson 4720
Anyone break the fuel filler neck off of their Branson tractor yet? Broke mine while bush hogging a couple years back. A sapling popped up and broke it right off. I didn稚 even notice until I started smelling diesel fuel. I was lucky enough to find it in one piece (sort of) and after trying some fancy dancy plastic glues, turns out that good old JB Weld held it on just fine. I am a lot more careful though about putting that side of the tractor into the brush.
:mad:
/ Broken Fuel Neck #2
Isn't the fuel filter behind the right side panel? I looked at mine and I am trying to understand how this happened to you. (so I can prevent it from happening to me)
/ Broken Fuel Neck #3
Yeah, my buddy down near Troup, TX has cracked the neck to tank joint on his. Now he can only put a few gallons in at a time. When I was operating it last month to work up his gardening project, it was sloshing and weeping. What a pain.
They do seem to have been vulnerably placed.
Anyone got a source for a replacement tank that doesn't cost a fortune?
/ Broken Fuel Neck
Fuel filler not filter.
The filler neck sticks out at an angle from under the right floor board on my 4720. A small sapling got between the filler neck and......something. I didnt actually see it get in there. The main thing is, is keep the right side out of the brush.
/ Broken Fuel Neck #5
Duh, that's what I get for reading posts without my glasses.
/ Broken Fuel Neck #6
The plastic tanks can be repaired very nicely with a soldering iron after you clean it. I'm not sure about JB-like weld on the tank, but the soldering iron melts the material together as if it wasn't broken. I did this for my gasser and it worked great. If you are interested do a search on repairing a plastic gas tank.
/ Broken Fuel Neck #7
I use a FEL to protect mine from direct impact. Good excuse to go buy one . . . no?
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
Wooden Glider Chair (A64557)
Wooden Glider...
2006 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2006 MAC 35ft...
Honda EM 7000is Inverter Generator (A64553)
Honda EM 7000is...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
