Broken Front Shocks
   / Broken Front Shocks #1
FordT
Yesterday while spraying a pasture sideslope I broke a front shock. Apparently something flew up and through my fender. I'm a bit disapointed as my other equipment traverses this same pasture without difficulty or mechanical failure. In fact I continued my spraying operation with my stock Ford Explorer without difficulty. Has anyone else had this problem?
   / Broken Front Shocks #2
Which TC version do you have?
jmf
I belive it's a B. How do you differentiate between A,B, and C?
   / Broken Front Shocks #4
The C has independent suspension.
jmf
Mine has solid axles so it must be a B.
   / Broken Front Shocks #6
The 'A' model has a box boom (can't see through the middle) and white arms from the boom to the tilt mechanism.
The 'B' model has a box boom (can't see through the middle) and black arms from the boom to the tilt mechanism.
The 'C' model has a two piece boom that is open in the middle (can see through).
The 'D' model is the only model (currently) with independent rear suspension.
dsb
OK mine is a B model.
Thank you both for your clarification. Any one else had shock/spring failure.
Ford
Thanks, I sent a message to him asking him to join the discussion.
FordT
   / Broken Front Shocks #10
As I recall, Dylan had rear leaf spring failure, not shock failure.
Do not recall anyone else having shock breakage.
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
