broken front draft arm brakets on a 54 inch deck
   / broken front draft arm brakets on a 54 inch deck #1
wanna
orleans county new york state
jd 1070
hi guys i have a john deer 425 with a 54 inch mower deck the front brakets on the deck broke off and i lost one theas are the brakets that the frount draft arm goes into i have one talked to my jd dealer he said that they dont have replacments and that i woul need a new deck nothing wrong with my deck other than the broken bracets and the missing one any thoughts on how to fix would be great thanks art
   / broken front draft arm brakets on a 54 inch deck #2
Local welder to make and weld them on.
I have the 54" decks and it must have taken a lot to have busted them off.
Maybe have kids using the mower?
   / broken front draft arm brakets on a 54 inch deck #3
check an online auction for a replacement
   / broken front draft arm brakets on a 54 inch deck #4
The reason those brackets broke of is because the deck has rusted some and the metal is thin. When you have someone make a hook, you also need to weld some 1/8 inch flat steel across the front and in the inside and it will last a long time, the 54 decks are thinner and if they aren't keep fairly clean the hooks break out.
   / broken front draft arm brakets on a 54 inch deck #5
my old JD mower brackets broke a long time ago, when th mower was only a few years old.. I made some new, beefer ones with some 1/4" angle iron. i still have the mower. its ugly but works great.
If you cant weld, a welding shop can fix you right up. i found that the brackets that came with my mower were far too thin to take the abuse a mower takes.
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2011 Doonan 482FBCHTTDBZ 53ft 40 Ton T/A Flatbed Equipment Trailer (A52377)
2011 Doonan...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
