broken front draft arm brakets on a 54 inch deck
   / broken front draft arm brakets on a 54 inch deck #1
wanna
orleans county new york state
jd 1070
hi guys i have a john deer 425 with a 54 inch mower deck the front brakets on the deck broke off and i lost one theas are the brakets that the frount draft arm goes into i have one talked to my jd dealer he said that they dont have replacments and that i woul need a new deck nothing wrong with my deck other than the broken bracets and the missing one any thoughts on how to fix would be great thanks art
   / broken front draft arm brakets on a 54 inch deck #2
Local welder to make and weld them on.
I have the 54" decks and it must have taken a lot to have busted them off.
Maybe have kids using the mower?
   / broken front draft arm brakets on a 54 inch deck #3
check an online auction for a replacement
   / broken front draft arm brakets on a 54 inch deck #4
The reason those brackets broke of is because the deck has rusted some and the metal is thin. When you have someone make a hook, you also need to weld some 1/8 inch flat steel across the front and in the inside and it will last a long time, the 54 decks are thinner and if they aren't keep fairly clean the hooks break out.
   / broken front draft arm brakets on a 54 inch deck #5
my old JD mower brackets broke a long time ago, when th mower was only a few years old.. I made some new, beefer ones with some 1/4" angle iron. i still have the mower. its ugly but works great.
If you cant weld, a welding shop can fix you right up. i found that the brackets that came with my mower were far too thin to take the abuse a mower takes.
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
