broken front draft arm brakets on a 54 inch deck
   / broken front draft arm brakets on a 54 inch deck #1
wanna
orleans county new york state
jd 1070
hi guys i have a john deer 425 with a 54 inch mower deck the front brakets on the deck broke off and i lost one theas are the brakets that the frount draft arm goes into i have one talked to my jd dealer he said that they dont have replacments and that i woul need a new deck nothing wrong with my deck other than the broken bracets and the missing one any thoughts on how to fix would be great thanks art
   / broken front draft arm brakets on a 54 inch deck #2
Local welder to make and weld them on.
I have the 54" decks and it must have taken a lot to have busted them off.
Maybe have kids using the mower?
   / broken front draft arm brakets on a 54 inch deck #3
check an online auction for a replacement
   / broken front draft arm brakets on a 54 inch deck #4
The reason those brackets broke of is because the deck has rusted some and the metal is thin. When you have someone make a hook, you also need to weld some 1/8 inch flat steel across the front and in the inside and it will last a long time, the 54 decks are thinner and if they aren't keep fairly clean the hooks break out.
   / broken front draft arm brakets on a 54 inch deck #5
my old JD mower brackets broke a long time ago, when th mower was only a few years old.. I made some new, beefer ones with some 1/4" angle iron. i still have the mower. its ugly but works great.
If you cant weld, a welding shop can fix you right up. i found that the brackets that came with my mower were far too thin to take the abuse a mower takes.
Miller Big 40 Portable DC Arc Welder Generator (A52377)
Miller Big 40...
LOT LOCATIONS (A54313)
2007 International 4400 2,000 Gallon Water Truck (A52377)
2007 International...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
John Dozer JD650 (A51691)
John Dozer JD650...
1472 (A51247)
1472 (A51247)
