Broken frame to engine bolts
/ Broken frame to engine bolts #31
Thanks 5030, I've used ATF and acetone before to loosen frozen rotors and have had good luck with it. I'll spray some on the broken bolts. I purchased the transfer punches and an ez-out today but so far I can't find anyone around my area that sells left handed bits so I may have to order some. The bolts turned out to be grade 10.9 and M12 x 40mm with a 1.75 pitch.
I love those transfer punches; use them a lot for matching up holes in fab work. I now have ones up to 1". Amazon has a set of LH drills up to 1/2". Not very expensive. I have the set but haven't used it yet; knock on wood. You my get lucky and they will not be sized up with corrosion and come right out.
Ron
/ Broken frame to engine bolts #32
Ron
What the acetone / ATF does, it breaks any corrosion bond. Always good to 'prep' prior to 'removal'.
/ Broken frame to engine bolts #33
Pounding on the slug when the OP center punches it should help loosen it too.
/ Broken frame to engine bolts #34
Every little bit will help I'm sure.
One thing for the OP, just remember to clean all the threaded cavities with brake cleaner before installing the new capscrews. The lock tite won't work if the threads are contaminated with anything.
/ Broken frame to engine bolts #35
It appears these bolts are grade 10.9 and the bolt also has an H5 stamped on it if that means anything. They are 1 1/2 inches long and my owners manual has no torque specs.
Online are generic bolt torque specs both SAE and Metric, dry, new, and wet. Just ask the question.
I have looked online for the torque specs. They seem to be all over the board depending on if the bolt is coated or black or dry or wet what ever that means. It appears from what I can make sense of is that the bolts I purchased should be around 85 ft lbs since they are coated. The plain black bolts , which I couldn't find locally, are aroung 93 lbs if I'm correct. I'm still waiting for the left handed drill bits to complete the job.
/ Broken frame to engine bolts #38
Actually, the best penetrating oil is basically free or at least a whole lot cheaper than say PBlaster. Acetone and ATF. 1 part ATF to 4 parts acetone in a squirt bottle. All I use. Cuts rust and frees stuck bolts and assemblies.
I have used the home made penetrating for yrs but i use it at 50/50 and shake before spraying. Best i have ever used!!
/ Broken frame to engine bolts #39
People treat torquing bolts as an exact science that has been engineered to a tee. But it isn't at all. It is an interesting subject to read up on. It supposedly relates to the holding force of a particular fastener, and it does if everything in the world was equal. However all sorts of factors enter in such as the quality of the threads, how dirty or how lubricated the threads are, if you use thread lock, if you use washers and what kind, the attributes of the fastener material. and on and on. These variables can change the actually stress put on the fastener (a measure of the holding power) and/or the limits of stress it will accept quite significantly. You are better off to use torque guides as a reference and then apply common sense from there on. More importantly is usually that a series of fasteners are tightened equally. On one extreme the fastener will loosen under use, on the other extreme it will break. You just need to be somewhere in between.
/ Broken frame to engine bolts #40
Should be a bolt torque chart in your owners manual. If not, post the diameter and thread pitch as well as the strength of the replacement bolt and I'll look it up for you.
As I recall the chart is at the very front of the manual....it's in mine.
GENIE AWP-24 MAN LIFT (A60736)
GENIE AWP-24 MAN...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2008 KALYN SIEBERT TRI PLEX FRAC PUMP (A60736)
2008 KALYN SIEBERT...
GMC 2500HD 4wd Service Truck (A61307)
GMC 2500HD 4wd...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
