broken Ford 8n seat bolt
   / broken Ford 8n seat bolt #1
EliD
Oregon
Ford 8n x2 Case 190
Hi this is my first post so I am not sure this is where it belongs. On my ford 8n I recently broke the seat bolt while trying to remove it (It is sheared off nearly flush). I attempted using an extractor but I did not drill my hole on center, so I was thinking of pulling the rear cover that has the 3pt on it to access the back side of the bolt.
   / broken Ford 8n seat bolt #2
I don't think that bolt goes all the way through.
Do you have a picture of the broken bolt?
I can upload one tomorrow. Thanks
The rear one looks to be a through hole.
I am wondering would it be easier to remove that top section from the transmission?
   / broken Ford 8n seat bolt #5
lay a washer around the hole and weld the shank to the washer, now law a big nut on the washer flange and weld the inside center ( stud shank ) and edge of washer tot he large hex nut.
after the red goes away, but still hot.. try to turn it out with a impact wrench set to LOW , lowest power... the heat helps.. and the hammering helps.
I use an impact on things that i think may shear on a straight pull..
   / broken Ford 8n seat bolt #6
ps.. you could also die grinder around the shank a bit and just go right to the nut and skip the washer..
   / broken Ford 8n seat bolt #7
I am with SG on the washer and the nut. My welding is not the greatest and I usually have better luck that way than welding inside the nut
   / broken Ford 8n seat bolt #8
Take a punch and split it at thinnest point then chip it out in pieces.
Sent from my Samsung SPH-L710 using TractorByNet
   / broken Ford 8n seat bolt #9
i doubt it will chip out. at best, if oem, it was a gr5 equiv bolt. i'd almost say turn it out with a chissle.. but i bet if it stuck enough to shear.. it's in ther eand the chissle will just make it shorter and harder to weld too ..
   / broken Ford 8n seat bolt #10
It would come out, split it, then take the chisel and work on it where it is split. It will curl up and come out.
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER REEFER (A52576)
2020 HYUNDAI...
Year: 2005 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2005 Make...
