Broken exhaust manifold
/ Broken exhaust manifold
Broken muffler #2 today, of course after hours. I am going to call them first thing tomorrow. Just clicked over 51 hours. Hopefully they will be as responsive and accommodating as they were when this happened the first time. Fingers crossed.
Mike
Update #1- Spoke with the Service Manager at the Dealer and he said it would be taken care of. I will continue to keep you updates.
Mike
/ Broken exhaust manifold #43
There has been issues with the EMAX mufflers for the last few months now. New updated muffler has a brace on it and a bracket that attaches to the alternator. Kit is available. PT# EC110024A
Great news....Dealer sent a service Tech. out to my house and replaced the muffler under warranty. When the Service Manager called me this morning I was a bit uneasy because he started to give the the "Your tractor is the only one that we are seeing this problem with". But in the end, its all good!!
They also delivered the snow plow so I'll be posting pics of the install on that in the coming days. Wish me luck. Oh and feel free to lend any advice if you have installed one.
thanks
Mike
Jab,
Just saw this. The Service Tech. did mention something like that but when he said it I was under the impression he meant that if he had to come up with a fix this is pretty much the way he would do it. I'll call the and see if thats something they can do.
Mike
/ Broken exhaust manifold #46
Mike I hope they did not put the same style muffler back on ! It will probably fail again. Have your dealer order the correct muffler replacement. That original muffler is no longer being used or sold. Give them the PT# I posted. Im sure they robbed another unit to get you up and running.
/ Broken exhaust manifold #47
I am currently in process of having my third muffler put on I had two mufflers of the same design fail where they were hard bolted to the frame then a new muffler without the frame bolt just failed and broke the pipe
/ Broken exhaust manifold #49
The hard bolt was replaced with a rubber damper. Should be an L bracket mounted to the frame,dampner and holed loop on the pipe. Sounds like the tech is not reading the instructions ! :eek:
/ Broken exhaust manifold #50
Are they using the same muffler as the origional ? Or Have they put the updated muffler with the new alternator bracket and brace kit in? The update kit should solve the problem.
/ Broken exhaust manifold #51
I had the factory-updated, EPA-approved new muffler installed and it has lasted fine for 220+ hours (after the original muffler broke at about 30 hours). I do try to avoid 1900 rpm or lower, since that seems to be where the most vibration/cavitation occurs.
/ Broken exhaust manifold #52
Dealer says musa is aware of the muffler problem and I will have to wait for their engineering solution...and no muffler in stock...anyway dealer is 45 min away and 5 acres of grass keeps growing an inch a day. I wired the muffler down securely in two places - 17 ga electric fence wire - and it stays tight at high rpms. Not happy but otherwise I think the emax was engineered well...hit a sweet spot in the subcompact class. I have not patented this broken muffler fix.
I don't think this is a muffler issue. My buddy and I both bought the emax25. Both on the same day. I haven't touched a muffler and he had his replaced and repaired a few times. They welded the original muffler twice, then replaced it with the newer version which included a bracket that goes to the alternator, and IT broke twice. Still waiting for the new muffler to come in. His tractor stays in a heated garage.
I looked at his engine when running just today (March21 2018). It shakes. It rattles.
My engine, even when it is cold outside and running rough until all of the cylinders fire, does not
shake at all. I took a video. I wish I could add it here, but I took it with my phone and can't transfer it here.
I think I would get the dealer to have a look at the motor mounts. When the snow finally is done for the year, he will be bringing his emax25 back to the dealer while still under warranty. I will post again if and when they find the problem.
One more thing. His tractor rattles at any rpm.
/ Broken exhaust manifold #53
Keep the machine above idle... the rattle at idle is what causes so much to shake apart on this machine.. not even 500rpms makes a huge difference on these machines .. they do have a new design for the muffler havnt seen any of the replacements break but I don't doubt it
/ Broken exhaust manifold #54
I agree. Mahindra should have set the minimum idle characteristics on this at the factory, because it takes very little extra rpm to make this three cylinder engine run with little vibration. All diesel engines vibrate more or less at different RPMs, and since this engine is rubber mounted to the frame rails the engine shakes. On the Max series (as opposed to the eMax) it is different, the engine/trans/rearend are all bolted together as a unit just like the big tractors. So you don't get much engine shake. In theory, the rubber isolates the operator from vibration, but it sure doesn't isolate the muffler.
As to eMax25's friend that has a rough running engine, for sure get that checked out at a dealer.
/ Broken exhaust manifold #55
I am interested to see how the new Branson owned Kekie or however you spell it goes inside the new emax
/ Broken exhaust manifold #56
We have sold over 100 Branson 2400's in the last few years, it uses the same little Kukje as they are now putting into the new eMax. it is for sure smoother. A good little engine. Kukje builds the A-series Cummins, they know how to build engines.
/ Broken exhaust manifold #57
Good to hear!
/ Broken exhaust manifold #58
broke_muffler1.JPGbroke_muffler_1.JPGbroke_muffler_2.JPGbroke_muffler_3.JPG.
I have an EMAX22GEAR I bought new in February of 2016. The first year, the loader bucket cracked and they replaced it. Last June, the original muffler failed where it attaches to the engine (first pic). Mahindra replaced it with their new "redesigned" muffler (2nd pic). After another 30 hours and 11 months, the pipe coming from the muffler just fell off (pic) These little engines just shake things apart. I'm concerned that I'll have trouble with this thing for years.
/ Broken exhaust manifold #59
View attachment 609718View attachment 609719View attachment 609720View attachment 609721.
There is really no excuse for the muffler failures. But there is a way to keep it from happening, or at least drastically minimize it. Raise you minimum idle a bit and the engine smooths out. When you idle down, keep the revs up a couple hundred RPM. Rubber engine mounts are pretty common on ladder frame tractors. I suppose it is to isolate the vibration from the operator...but it sure doesn't isolate the vibration from the muffler. I'd ask Mahindra to supply you with another muffler and then keep the idle up.
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
EZ Trail 510 Grain Cart (A64047)
EZ Trail 510 Grain...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2021 John Deere 320R Loader (A63116)
2021 John Deere...
