broken chain JD 219
   / broken chain JD 219
Hello again with more trouble. The baler was put into service after a year under cover but after making one bale, the long front to back chain broke. However unknown to me, the chain was repaired and run again without the timing being attended to. Needless to say, one of the needles was bent sideways from the feed chamber and the tucker cross shaft bent.
A new needle has been ordered and will be fitted. I also noticed that the rod from the back that operates the piston stop is seized.
If that had been working, would the damage have been avoided?
   / broken chain JD 219 #12
Yes a correctly operating plungerhead stop should protect needles when needle to PH timing is incorrect. Be sure needle brake is snug enough to hold needles when they're in home position.
Thanks, I will have a look tomorrow.
H
I got the timing right eventually after wrecking a needle due to hay packing the piston slots and bad timing.
Does the long chain from the crankshaft to the knotter gears have any timing issues, or is it ok to reconnect?
That chain has been broken several times in the past without breaking the shear bolt. It has a 1.5x 0.5 pitch. Where can I get one from? The machine had been left outside for many years when I got it.
202475 (A54757)
202475 (A54757)
2017 Ford F550 (A55973)
2017 Ford F550...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A55315)
2019 Cadillac...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
