Backhoe Broken backhoe; how to get it back together?
   / Broken backhoe; how to get it back together? #1
old and tired
Raleigh, NC/Hillsville, VA
L2800 HST
Not mine but a friend's backhoe; I will be helping to get it back together (hopefully). I can say that the price of this backhoe was affordable. Not sure of the make, it has it's own PTO pump and it tried to move a rock that wouldn’t move. Looks like 3/16 inch thick plate that bent. Piston in ram is twisted.
Would a 20 ton press have a chance to bend this back? Does it need to be heated? Assume the ram needs to be replaced, any chance to bend it back??
If we get this back together, next questions would be to how to reinforce the sides... Thanks for any help you can give us.
   / Broken backhoe; how to get it back together? #2
Hydro cylinder seems to be in a bind with the pin. Did the pin break ? Drive the pin out to check the cylinder. The twist is nothing. All rods twist. A bend in the rod is bad. You'll need heat to straighten the plate. I don't see how a 20 T press will work. A oxy/acc rosebud and a hammer will work. A propane torch will not. Get a rattle can of paint to finish.
   / Broken backhoe; how to get it back together? #3
Well, a good hydraulic shop can tell you if they could straighten it. If not, they could make a new rod and end for the existing body.
   / Broken backhoe; how to get it back together? #4
It’s hard to tell in the photos if the cylinder or rod is damaged. Normal for rod to turn.
Insight into what happened?
Heat, clamp and beat to straighten gusset. May require some plate reinforcement.
50ton press would work. Thing with any press is having all the associated tooling to safely straighten. The potential energy slipping and being suddenly released requires careful operator attention.
   / Broken backhoe; how to get it back together? #5
Gotta be a good story on how that happened.
As said above, drive the pin out of the rod and see how straight the rod is or isn't. The stick is gonna take some heat and a really good press or big hammer to make it right but I would still have to go back to what happened? Pretty sure this should have been apparent to the operator as it was happening.
   / Broken backhoe; how to get it back together? #6
Think this is one for heavy eq. repair shop.... Simple for them, difficult for you...
But if you insist, I would get the ram off the pin first then reevaluate...
You have two issues here...Possible bent ram (almost certain unless it goes straight when pin removed) ..
Double bend in sheet steel of arm where pin bosses are, if you don't get it right (alignment) its just going to be a bear to fix...
....Insight into what happened?
Story from him: "...A puzzle story. I was pulling up roots, took a break, and walking back to tractor found a lock washer and a regular washer on top of dirt next to backhoe. Looked all over the backhoe to find where they came from and completely missed seeing the bolt missing from that retainer bracket. I actually pulled up several more roots before tackling the rock that wouldn’t move that caused the damage. Can’t figure out how the missing bolt caused the failure since the pin bracket stayed flush with the bent metal. The bolt just held the bracket retainer in place. It didn’t move..."
Thanks to all that have replied...
   / Broken backhoe; how to get it back together? #8
You may can put some big all thread through the pin holes with washers and nuts, to pull as you heat. A machine shop can straighten the ram.
You can cut those plates a little so you won't have to bend as much steel. Only if you can weld back later.
....You can cut those plates a little so you won't have to bend as much steel. Only if you can weld back later.
Yes I did think about that, wondered if that was an option (since we don't have a torch) and yes I can weld it back.
   / Broken backhoe; how to get it back together? #10
That kinda explains it...
Retaining bolt fell out. Pin backed out of the far side. Near side bent, and as the ram extended, it bound on the pin and pulled it back up against the near side plate.
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
