Broken already!
   / Broken already! #61
I've been following this thread and you said it was at the dealer and would be fixed by Friday. Well, I can't stand the suspense<smile>....did they get er done?
You know in todays complex world with redundant safety devices and complex electronics I think virtually all vehicles have some kinda little ah oh when new. I know I haven't bought any in years and I buy one each year at a minimum and all have had some issue or other. Many of my friends just ignore the little things cause they don't wish to take the time for dealer repair. Not me my year old jeep has 19 service tags for the same issue still not fixed
   / Broken already! #62
I think you have it right.... Simple ohmmeter test between plug on end of harness (at dash) and connector at temperature sensor on engine block would confirm if its a "wire" issue...
Dale
Actually it's a single wire, temperature sensor is resistive ground from(?) engine block to plug on PC board panel......
THis I found out trying to find issue with my new 1715 with less than 2 hours on it to find loose screws on printed circuit board holding mechanical part of gauge to printed circuit board.......
Dale
   / Broken already!
I got it back, but not fixed.
They are going to replace the entire wiring harness, rather than cut and splice the one on a brand new (less than 30 hours) tractor. They are waiting for the new harness to come, then will contact me about picking it up to replace. I can use it in the meantime, and my grass does need mowed.
I may be able to have the old harness, they have to hold it for up to 90 days, until MF tells them to send it in or destroy it.
I want to add fuses to my fuseblock, for a light circuit, and I should be able to pull the old ones out of the old fuseblock.
I'm pretty happy with my dealer, JAVA Farm Supply, in Westfield NY. Formerly Rammelts, still run by the Rammelt family
   / Broken already! #64
Thats great! I have tons of lights on my old tractor and often in the hot summer just keep going until way into the night especially if my tool box on the tractor has cold beer in it.<smile>
   / Broken already!
Another issue popped up. The glow plug light now does not work. I think the glow plugs are activating, because the oil pressure and charging lights dim a bit.
   / Broken already! #66
so you got it back already with the new wiring harness and more issues? If you still have the old harness I'm not surprised. Your symptom indicates a short in the wiring. Tractor is new so if it burns up they will have to fix it.
   / Broken already!
No, not the new wiring harness.
They brought it back to me to use while waiting for the new harness to arrive. I think they might have bumped something while diagnosing the problem.
I will advise them of this new symptom, to be certain it is also fixed with new harness.
   / Broken already! #70
Good move. I figured thats what was going on. How long is it going to take them to get a harness?
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A55787)
2020 Kubota Z723KH...
Killbros 375 Gravity Wagon (A50775)
Killbros 375...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2016 Ford F-550...
Electric Scissor Lift (A55787)
Electric Scissor...
