Broke my new cutter
/ Broke my new cutter #1
nybirdman
Super Member
north of upstate ny
Kubota L4240 HSTC,L3000DT
With just about five hours on my new Landpride LCR2072 managed to break one of the blades.My fault hit a rock.
It snapped about a foot off of one of the blades,made quite a racket and serious vibration.Dealer to pick up soon.
I don't believe it will be covered under warranty but we will see.
Next project;ordered the materials to start my tree shear build and will post on it's progress.
/ Broke my new cutter #2
Thank goodness no one was injured. I've heard of guys having all sorts of difficulties with rear cutters but snap a blade. Are the blades brittle or was it just an unlucky hit?
/ Broke my new cutter #3
I'd look carefully at the broken blade to see if there is any evidence of a pre-existing crack/fracture/flaw in the metal. I'm sure it's possible to break a non-defective blade, but it's unusual.
/ Broke my new cutter #4
NEver heard of breaking a blade before. What size are the blades (width and thickness)?
I have hit a fair share of stumps and rocks and never broke a blade. The blades swing free and absorb lots of the shock. I did hit a giant chunk of concrete once and broke the blade bolt, and have seen bent blades, but never one broke clean off.
/ Broke my new cutter #5
I've never heard of an LCR2072 before. Is that a typo? I don't even remember an RCR 2072 either, only RCF.
Is this a light duty cutter?
/ Broke my new cutter #6
Broken rotary cutter blades have been reported on this and other sites not infrequently and quite a few highway departments have replaced rotary cutters with flail mowers according to some threads I've read. I've never broken one, but we don't have exposed rocks on our farms where we mow.
I miss- typed RCR2072,considered a medium duty 6ft.719lbs.
I never operate with any-one in the area and this is why.I have about 800hrs on my 5ft.Bush-Hog branded BH and was cutting the same areas.I have hit a lot of rocks ect.but rarely sheared a pin on the BH,this one has a slip clutch and didn't service because it was brand new.I don't believe the slip clutch would have helped anyway.
/ Broke my new cutter #8
I have never broken a blade either. On an old Ford Linkbelt 6 foot finish mower I did "wad up a blade" once when I rolled a large rock under it. It smoked the belts in a hurry, let me tell you. The blade looked like a pretzel.
/ Broke my new cutter #9
I broke a blade on our squealer. It broke right at the bolt hole.
/ Broke my new cutter #10
/ Broke my new cutter #11
Neighbor had a old blade on a old Howse cutter break without hitting anything. Very odd. It sure woke him up though!
/ Broke my new cutter #12
I've broken many many rocks, but never the blade. About the only thing I DON'T mow is nice grassy fields and very small saplings.
/ Broke my new cutter #13
I'm in the haven't broken a blade "yet" club. Ive dinged the snot out of them and replaced numerous pairs, I'm thinking maybe a poor piece of steel used :confused3:
/ Broke my new cutter #14
Years ago I broke a blade in a 6' cutter, I lifted it over a stump but dropped it back down too fast and it hit the stump hard. It rattled like heck because of the very unbalanced unit. I replaced both blades with a set from TSC.
/ Broke my new cutter #15
Mower blades (rotary and finish) are designed to bend not break. Glad no one was near when it let loose! Did the blade penetrate the side of the mower or did the mower contain the blade? I know that there are lots of ASABE, and ISO specs regarding test that rotary cutters must go through. I had the opportunity to see some pictures of Woods's testing facility for rotary cutters. A lot more work goes into making rotary cutters safe than I would have thought.
