Broke my front end
/ Broke my front end #21
I've seen that flick, a very good dramatization (not documentary) starring Tom Hanks. Thousands of engineering man-hours, DT and NDT got everything to that point. Despite all precautionary measures, accidents can and will happen but you don't have to ask for it.
Believe it or not, there are schools where you can get educated about operating tractors. There are also books to read about slopes, angles, weights, etc.
Your tractor, your call.
/ Broke my front end #22
You can't tell me you haven't gone past your Pucker factor on your tractor and realized you shouldn't of done that.
I am new to my tractor , and my manuals don't tell me how to judge what something weights ? or how much slop angle I can traverse? its not till I do it do I find out what my limits are... So I go by: if I can't lift it with the FEL, I will tow it, if I can't tow it , I will leave it... I certainly don't what to brake my tractor...
Somebody remind me never to fly with this guy
//greg//
/ Broke my front end #23
greg-g ,,, that was uncalled for.. I am not trying to insult people in here way are YOU. :confused:
bob ,, when I learn how to read I will certainly pick up one of them books..:rolleyes:,, thanks for the heads up..:D
/ Broke my front end #24
with all them comma's.. I'm having flashbacks of 'thingy'
soundguy
/ Broke my front end #26
grammar, and spelling.. as long as it is still readable isn't a big deal. I now have to type on a lil 'chicklet' laptop keyboard and my spelling errors went up about 50% vs a regular full sized 104 key keyboard...
soundguy
/ Broke my front end #27
WOW!
But I still feel sorry for those guys trying to punch out War and Peace on their Blackberries.
/ Broke my front end #29
Have you thought about pulling the other side down, and just checking it for a twisted shaft?
It would not suprise me in the least if the other side was twisted some as well, I may order the second axle just to have it. But I will not dissasemble until it breaks. I only use my tractor for personal, so It wouldn't affect me alot if it fails prematurely. If I was working on contract I would change it for sure.
/ Broke my front end #32
This discussion makes me want to ask: when I am using FEL to move crushed lime, should I NOT be in 4WD? the koyker 160 on my 224 picks up things fine, but now I am worried about damaging the front axle ....
Only thing on the back of the tractor would be a rake. so not much weight. I have read posts about staying out of 4WD when on the road; but when I am not on the road, I have the tractor in 4WD all the time. Even for pulling the 6' mower. Is that wrong?
Am I loading up the front axle too much?
/ Broke my front end #33
The Jinma 200 series seems to be the only Chinese tractor that has gathered enough customer complaints to warrant warning against aggressive loader work in 4wd. I don't own one anymore, but would personally have no problem doing nearly everything (off pavement) in 4wd - except aggressive loader work. Both my current tractors stay in 4wd nearly full time, only shifting into 2wd on the rare occasion I have to go up on the highway.
//greg//
/ Broke my front end #34
1#; when I am using FEL to move crushed lime, should I NOT be in 4WD? the koyker 160 on my 224 picks up things fine, but now I am worried about damaging the front axle ....
2#; Only thing on the back of the tractor would be a rake. so not much weight.
3#; I have read posts about staying out of 4WD when on the road;
4#; but when I am not on the road, I have the tractor in 4WD all the time. Even for pulling the 6' mower. Is that wrong?
5#; Am I loading up the front axle too much?
Here's my opinion, applies to all 4x4 tractors doing front loader work.
1#; unless you are operating the tractor in slick conditions you should have plenty of forward traction in two wheel drive (with aig tires) to fill the bucket with proper rear counter weight. R4's & Turfs dont bite the ground like aig tires.
2#; Correct. I sell 99% of all my new tractors with the rear tires loaded that get a loader. Depending on bucket material weight more rear counter weight needs to be added. You must keep the rear tires biteing the ground. Proper tire pressure allowing full bar/tread lug ground contact of 2 1/2 - 3 bars is what I like to see use.
3#; Right / correct.
4#; I can say it's wrong but, I would not have it in 4x4 if I did not need 4x4.
5#; Don't know ??
With 4x4 engaged the front wheels try to out run the rear wheels. Which means the front wheels are / have to slip/spin. That is why you see or will see the front tires wearing more than the rear when 4x4 engagement is used a lot. The harder / aggressive the tire contact surface is speeds of the tire wear.
When you raise a loader bucket full of material off the ground that has any weight to it the rear tires loose full ground contact/traction (rear of tractor gets light). You then try to back up and the rear tires just spin (want move). Then you reach down and put it in 4x4 ( thats why I have 4x4 right?) now I am asking the SMALL front differantial assembly to move the whole load ...... tractor & material. Then one wonders why something broke in the front drive assembly. Rear counter weight is KEY !!. This is just one example.
Here is a copy and paste from here; TractorSmart home page
This serves to illustrate why it is important to be judicial in the use of 4wd, avoiding usage on hard surfaces as much as possible.
A related subject is the use of front loaders on front wheel assist tractors. Ideally you want to maintain a load bearing ratio between the front and rear axles of 40%front/60%rear. Asking the front axle to carry more than this share is setting yourself up for expensive repairs down the road. It is important to use appropriate counter-balance on the rear of the tractor to offset the loads that are carried in the loader bucket. Take note that front axle components are generally smaller and of lighter construction than the rear axle. These front axle components were not designed to support 60%, 70% or in some extreme cases up to 90% of the total "load".
If your rear axle is scooting along, just barely contacting the ground now and then, this means the front axle is supporting near 100% of the total weight of the tractor, loader and bucket payload! This is an almost iron-clad guarantee of front axle failure!
Ronald
Ranch Hand Supply
/ Broke my front end #35
Thanks for the explanation. Makes sense. I probably have been lucky doing all loading in 4wd. I was under the impression that I could plow into a pile of gravel with more usable force if in 4wd...I will be paying attention to that now.
/ Broke my front end #36
TSSmart:
I broke/tore off my front wheel, (fell onto the housing) as the wheel & drive shaft rolled off / out of the front end drive / steering knuckle assy. This was from leaving it in 4x4 and moving sand/dirt/clay. granted I had dipped the bucket a little too aggressively and it pulled deeper than I wanted. I missed the clutch as well which twisted the axle in half as much as added extra load when lifting the bucket up/into the sand. If you search my old posts here I'm sure you might find some pics. I can add one
there are more pics there is you back up to view them... BTW: Tommy @ affordable was great to get me the parts I needed, I think grand total was pretty cheap for the damage I did... worst was I lost several weeks of tractor useage when I really needed it. shipping I got damaged seal from the housing crushing it and tommy got me a replacement seal & I added som e bearings to the 2nd order that I felt should be changed which added time to the repair..
Mark
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
generator trailer (A61569)
generator trailer...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
CAT CB34 (A60462)
CAT CB34 (A60462)
