Broke Hydrostat twice? Why?
/ Broke Hydrostat twice? Why? #21
As mentioned before, I would REALLY want to see a teardown report on that unit. Paulfun9 suggested paying for it & I agree wholeheartedly! If you are gonna keep that tractor, the peace of mind (if nothing else) would be worth every penny spent. It would likely take less than an hour of shop time. You probably don't need a formal, written report. Many shops are reluctant to put such things in writing, for liability reasons. If you ask for a verbal report, that may overcome any reluctance you might encounter.
My history is in the aircraft industry, where premature failures are routinely assessed to discover the cause & prevent future occurrences. A quality teardown report is worth it's weight in $$$.
/ Broke Hydrostat twice? Why? #22
You state the manual said.
"Place range transmission shift lever in neutral. Start engine and run at full throttle. Slowly depress forward directional pedal. Gauge should slowly rise to approx. 130-170Kgf/cm2, 1848-2417 psi and relief valve will open with an audible squealing noise if the pressure rises to over 350Kgf/cm2. Repeat with reverse"
I don't see how it can build pressure if there is no load on it. For sure the relief couldn't open when the tractor is in neutral. The transmission has to be doing work to build pressure. What am I missing?
/ Broke Hydrostat twice? Why? #23
Just thinking outside the box here. Could it be possible that the bypass valves are getting sticky when they get hot from the oil going through the system. Leading to shock loading which lifts the pump off of the mating surface and then slams down when pressure drops to normal levels, like when you ram into a pile of dirt and suddenly stop or change directions.
Leejohn
I think you hit about 2000 psi in neutral at redline and about 5000 psi as you push the go pedal while pushing against a wall or something.
OK, I just called Jordan in Post Falls, Idaho.
They agreed to pull the old hydro apart though it might be a couple of weeks before they can get to it.
I offered - then insisted on paying, but they refused. Said they were curious too.
Did I tell you that while they were working on the hydro they unilaterally decided that my tractor body was ratty looking after 8 years of hard use, so they replaced it with an almost new one they had because they had replaced one under warranty cause it had a tiny bit of paint peeling? No charge.
So I'll keep the radiators clean from now on and will report back when I hear from Jordan.
Oh, and another thing Jordan reminded me of.
They removed the tranny strainer to see if there was any shrapnel in it and there wasn't.
And the oil was clean and looked good.
/ Broke Hydrostat twice? Why? #27
I have often wondered what the proper RPM is.
I almost always run at about 1800 RPM. Red line is 2700.
I agree with everyone that finding a resulting cause to your issues is a high priority, in the mean time I would say that while 1800RPM should be fine in most instances for most machines; after having two failures I would use a higher RPM. HSTs love flow. They run cooler and last longer the more you fluid you feed them. They are designed for and tested at PTO speeds as a minimum as the most common tasks generally work best at full PTO speeds. Generally if you closely examine the speed charts provided with newer HST tractors, the speeds are rated at RPMs higher than the PTO RPM, and in many cases they are rated at the governed RPM redline.
I have never heard of such a thing as running the engine too hard for the HST to handle, but there are many documented cases of not having enough flow and wearing/overheating/ruining the HST. Till you get it figured out I'd operate at an RPM you know it is spec'd to run at such as PTO speed.
/ Broke Hydrostat twice? Why? #28
Fluid flow is controlled by changing the angle of the cam plate.
This angle is controlled by the operator through a mechanical linkage"
Does this even answer your question?
Yes. You have a mechanically controlled HST, as expected. What TYM calls a "cam plate"
is known in the industry as a swash plate. The photo shows one kind of swash plate,
from a McCormick HST unit. The lever arm tilts the plate to change the volume and
direction of the HST pump flow.
/ Broke Hydrostat twice? Why? #29
He tested the hydro at the test ports and got about 500 psi.
I believe he followed the manual which states:
Given that the test was done in a no-load situation, I would expect something less than 500psi. The
test procedure looks plain wrong. With range shifter in neutral, the HST pump in FWD or REV is only
driving the internal gears and other parts. I few hundred PSI max, IMO.
Kudos to LEEJOHN for also seeing the mistake. My main tractor is also Korean, and the manual has
lots of errors. BTW, my Kioti CK30HST uses 2 independent RVs for the FWD and REV directions,
while the newer HST on the CK35H uses only one shared relief.
Here is another photo of an HST's guts, this time a Kubota B21.
I would do a post-mortem on your HST for the postage, Bob, if your mechanic does not
get to it.
I think I was making an assumption about how my local guy did the test based on my interpretation of the service manual and since either or both of those things have been shown here to be wrong, I will try to find out from my local guy just how he did do the pressure test.
Dfkrug, that is a very generous offer and if Jordan fails me (they really are very busy) I'll take you up on it.
Back tomorrow with more info on the testing.
/ Broke Hydrostat twice? Why? #31
They replaced the tractor body? For free?
Ive been to jordan's. Seem like good people. Now i want something free. Haha
Yes, free.
And they are good people. Not just because of the body either.
They treated me like everybody here wants to be treated by their dealer, and remember I didn't even buy the tractor there.
/ Broke Hydrostat twice? Why? #34
Any idea why the dealer happened to have a used hydro available? Seems unusual unless he rebuilds failed hydros during the winter to be available for customers like you who need one immediately during the peak season.
That's what I was wondering about as well. I wouldn't expect that to be an easy part to source used, but there may be a reason for it if that model has a history of failing.
/ Broke Hydrostat twice? Why? #35
That's pretty cool!
As far as I can tell these tractors very much do not have a bad history with hydro stats.
Jordan had recently taken in a low mileage TYM 273 in trade that had somehow been burnt.
They took it apart and put the parts on shelves. I did know this before I chose them to work on mine.
It's either over loaded or under designed . That is why it's breaking.
Thank you for your input but could you be more specific about what over loaded means?
I ask in all honesty because others have suggested that it may have been overheating and I can see that through ignorance or laziness (you pick) I could have contributed to that.
What sort of things would constitute over loading? Would they all imply over heating?
It's important because if heat is the enemy here, I can fix that with better habits plus a trans temp guage,
But if I'm just asking the poor thing to do too much, then I have the wrong tractor size
or the wrong tool entirely, and I have no reasonable fix for that.
Bob
/ Broke Hydrostat twice? Why? #39
If you send it to me, I will take it apart and post photos on TBN as I do with my other project threads. Your
only cost would be shipping to me, and back if you want it.
Note that most tractor repair shops do not rebuild engines or transmissions. Even the good ones.
Note that most tractor repair shops do not rebuild engines or transmissions. Even the good ones.[/QUOTE
Ok, Jordan doesn't want to rebuild it and they say that TYM won't sell internal hydro parts. But they did say that they would try to do a postmortem on it soon.
If not, I'll gladly send it to you. I am seriously grateful for all the help I got here 8 years ago and again now and I would love to help pay back.
Heck, if you like, my wife and I could maybe schedule a road trip and drop it off and maybe help (or more likely watch) you work on it. We're retired and love driving.
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2006 John Deere 6420 (A64126)
2006 John Deere...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
