broke frame
/ broke frame #2
My friend has that tractor, and what should I warn him about?
How did it crack? Any idea?
Backhoe?
/ broke frame #3
any one had a frame cracked on there 3215???
Talk about "ABUSING" a tractor...you should have gotten a D10 bulldozer instead. From your previous posting.. let's see....
1) Diff lock not working
2) 4WD engagement issue
3) Now a broken frame
To me this shows all the signs of operator misuse!
/ broke frame #4
Maybe it is the tractor and not the operator. Do we really know?
/ broke frame #5
Those failures all show the same thing and it's the failure of the operator to either know how to use the tractor or to perform the correct maintenance on it. It takes a lot to break or crack a tractor frame and the most likely reason is failure to keep the bolts tighten. The other problems all point to the operator not reading the owners manual.
/ broke frame #6
I would love to see a photo of his tractor? or does he even own one? I like seeing broken stuff and hearing the story that goes with it.
/ broke frame #7
Rubbing my chin on this one..pics would help also last couple of projects.
/ broke frame #8
I just bought a 3215 and the dealer called me up and said that there was a frame rail kit that needed to be installed. He offered to put it in but I dont want to loose the tractor so I picked up and I'm going to install. I'm away from home for the next couple of days but when I get back I will take some pictures of the kit and post.
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2017 Link-Belt 350X4 Hydraulic Excavator (A64553)
2017 Link-Belt...
2022 EZ-GO ELITE...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
