Mahindra low coolant/overheat shut off?
   / Mahindra low coolant/overheat shut off? #1
whitravis
3215 Mahendra
3215 radiator ran dry while I left it running to purge air. New tractor to me but obviously poorly maintained.
Small puddle of antifreeze on the floor and tractor had shut down.
Now it's no crank no start. Main fuse blows immediately when key is turned. Is there a look coolant switch
   / Mahindra low coolant/overheat shut off? #2
Main fuse blows when you turn the key wouldn't be a symptom of a temp switch or coolant level.
Is the starter getting fire and since the motor locked up, getting the max locked rotor current and blowing the fuse?
   / Mahindra low coolant/overheat shut off? #3
Sounds more like the engine is seized from overheating. See if the engine can be turned over by hand.
Thanks, that's the next plan. It's in WV 4hrs away from me, can't go for a while, so getting ideas, input.
