Hi,
Found a bolt on the ground. The end shows it snapped off flush with just little tab sticking up.
The blue paint told that it came from the Ford tractor and a search found that it is one of the two bolts that hold the engine to the engine cradle. Bolt goes in to the front of the engine block thru a rubber isolated grommet. It's unique to the HD Industrials model 1801 and 4140.
Looking up, you can see the water pump pulley on the right and the radiator hose on the left.
Anyhow, the place where the bolt goes only has about 5-6" of space in front of it and limited space around it. It seems like the only way to get to it is to take the frigging front half of the tractor apart. Remove the nose cone with lights and hydraulic tank, front pump, hyd lines & filter, power steering lines and cylinder and then the front end with the engine cradle. I figure it's about 10-15 hours of work. Not something I wanted to find out !
Any ideas on how to get this sucker out with less stress and effort?
Thanks!
jb
Thanks!
jb
