Broke a tiger tooth - Welding help
   / Broke a tiger tooth - Welding help #1
brianMO
Missouri
TYM T330 w/ lt300 loader
Hello all,
Kinda bums me a bit. My tractor is only about 6 weeks old. I was trying to turn a trailer back on its upside with my bucket. I must have binded a tooth. This looks to be a cast metal. It is a clean break. I was wondering if I could just weld it with 6011 to get the pentration, then top it with 7018. Should I heat it up with a torch, weld it then cool it slow. Should I anneal it? I need some advice. Nickel rod? I will try to send pics.
   / Broke a tiger tooth - Welding help #2
Often those are just pinned on, can you replace the entire thing?
I would weld it if I could not just replace it because the effects of a failure would be pretty minimal in my opinion. The rod combination above, and slow cooling should be fine. I would probably cool in a sandbox.
These do have the replaceable teeth for the ends, but that did not break. I broke before then. Do you think I need to heat it up really good first?
   / Broke a tiger tooth - Welding help #4
Got a picture?
If it is the "mount" for the tooth, it was probably designed to be welded anyway, I would imagine that it is welded to the bar or the bucket.
So, yes, I would weld it, I am picturing a large cross section so yes, I would probably go ahead and pre-heat.
I would probably call Allen at Markham welding and just ask if he would share some advice as I think he does it daily.
I will try to get the pics tonight.
the pics
   / Broke a tiger tooth - Welding help #8
It really wants 'V'ing out so that you can weld from the bottom to the top . Why is the lower leg not welded to the bottom of the bucket ?
Looks like an add-on tooth bar. Might unbolt the tooth bar to v-out and weld easier.
Could also, shiplap/weld additional steel to the shank for extra strength.
This repair is very do-able!
Good luck
   / Broke a tiger tooth - Welding help #9
Grind off the welds holding that shank to the cutting edge & replace the shank with a new one. You don't want to do this job twice to save $25 on a junk shank. MikeD74T
I think I will try to weld first. I understand the doing it twice concept, but I get a charge when it does work for several years. If it breaks again I will replace the shank. Why spend extra money. Afterall, I am supposed to be a welder! What do you think, grind smooth, V out, heat up to 300 or 400 degree with my o/a, and hit with 1/8 7018 at about 140 amps dcep? Might as well strengten all while I have the bar off.
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
BESTWAY AG VSK35 LOT NUMBER 126 (A53084)
BESTWAY AG VSK35...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
