Broadcast seed onto bare field?
   / Broadcast seed onto bare field? #11
Did you go back over it with anything after broadcast seeding?
No. When I do the 12 acres I am likely going to also fertilize and possibly flip the drag harrow over so the scarifiers are pointing up and drag again to cover the seed.
I may also call the local ag extension and see if they have a cultipacker I can rent.
   / Broadcast seed onto bare field? #12
I have done several fields broadcasting grass. It works fine. I set it a little light and travel it twice at 90 degrees to each other. I pull harrows at the same time (usually).
Oats works well with a broadcaster too (as long as the moisture is near the surface.
I find no need to pack or drag harrows upside-down.
I have done this in clayey sand and sandy clay with good results. A little rain after seeding is always welcome..
   / Broadcast seed onto bare field? #13
Ps, no need for chemical killers in a hay field. Under normal conditions and a couple of cuttings the desireable species will prevail.
   / Broadcast seed onto bare field? #14
Prima facie evidence that Johnsongrass doesn't grow in northern Alberta.:)
Steve
   / Broadcast seed onto bare field? #15
Apparently not, as I have never heard of johnsongrass.
I will google it. Ha. Fricken google is amazing when you sift thru the b.s.
   / Broadcast seed onto bare field? #16
Looks like food to me, as long as there's only a little of it. Apparently cutting it weakens it. As cutting does with most of the undesireables.
Hay is supposed to be a mixed salad, not a monocrop. IMO.
I have a book on poisonous plants for horses. It is a little ridiculous. As it turns out, everything when ingested solely is poisonous to horses. Variety is health.
We worry about alsike clover, too much alfalfa, and various other plants when it comes to horses.
This year is a bad year for alsike clover for us...
   / Broadcast seed onto bare field? #17
Yeah we had a mono crop of some yellow flowering weed. Forget what it is. Send that to our vet. He had it looked at by Purdue. They said toxic in large quantities. So we tilled under the initial sacrifice paddocks we built. Various grasses have grown back. Now we are working on the larger 12-18 acres we are going to keep them on. So we want to start it out well. Roundup is not that expensive. It will end up costing me about $250 in roundup to do the whole area.
Then you need to plant a good mix of various grasses and legumes. The mix you want for pasture is different than if you are going to bale hay from it. Also differs depending on your region as to what grows well of course.
What do you guys think about this hay mix and the percentages? Feel free to adjust the numbers or let me know of anything else to add. I like my hay to be leafy, low on stems and to have variety. This will be in southern Michigan for sheep and cows. I was thinking orchard grass, timothy, perennial rye, alfalfa a little bit of clover. Will the rye live through the winters here? Should I add any bluegrass? I see it in the pasture mixes but don't see it in any hay mixes.
30% orchard grass
30% timothy
25% alfalfa
10% rye
5% Clover
and is this math correct? Lets say it calls for 20lbs of alfalfa per acre. If I'm doing it at 25% it would only be 4lbs per acre and then 40lbs for all 10 acres?
   / Broadcast seed onto bare field? #19
In this part of the world we seed alfalfa at 12lbs+/acre. I usually put in some smooth brome and maybe a little timothy. As the field matures over a few years the grasses find their place and then the weather determines what grows where and when. For example, usually my hayfields are predominantly alfalfa in the lower areas. This year, due to good spring moisture and then no rain, the low areas were too wet for alfalfa, so for the first time in years the low areas are dominated by clover and the high ground is alfalfa. It changes every year and sometimes dramatically. If you want legumes, then seed the alfalfa at full rate for an alfalfa crop. Throw in some other grass seed as an addition to the mix; don't reduce the alfalfa by a proportionate amount. At least that's how it works around here...
We usually put in a cover crop of oats or rye or something to provide shade for the alfalfa. If we put in rye here it only exists the first year (annual rye).
Anyway, the experienced locals in your area will know what to do.
If you want a longlasting field then use old varieties. If you plan on redoing it every few years, then find the highest yielding new varieties.
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Kawasaki KLX140L Dirtbike (A59225)
Kawasaki KLX140L...
CHALLENGER MT575D (A58216)
CHALLENGER MT575D...
