Brighter Light
/ Brighter Light #1
Gomez
Bucks County, PA
Kubota B2400
Does anyone know the part number for the 55W light bulb to replace the wimpy 12W on the B2400? I did a search, but can't find the number.
/ Brighter Light #2
I'm using 27W bulbs in my B2400. I think they are normally used in trailer brake light assemblies. They work just fine for me (when the bucket doesn't block them).
I don't know if the lens assembly & housing can handle the heat from a 55W bulb. I think things would start to melt or burn.
JC Whitney has the bulb you want in their "Everything Automotive" catolog. Try this URL: http://www.jcwhitney.com
Peter
/ Brighter Light #3
Gomez,
There was some talk about this in the past. Try a search to see what was said. If I remember right, those who know electrics better than I said 55w bulbs would draw more amps than the system can handle.
I would think Peter makes a good point about the heat also.
MarkV
<P ID="edit"><FONT SIZE=-1>Edited by MarkV on 07/10/01 09:51 AM (server time).</FONT></P>
/ Brighter Light #4
I changed out the bulbs shortly after I got my 2710. They were the 27w versions that had a hard job lighting up my sidewalk let alone the field ahead. I got 50w high intensity back-up bulbs from my local Auto Zone store and installed them. What a difference !!!
Now I can see when it gets dark. No problems with the fuse as they only draw about 8 amps on a 10 amp fuse.
Stay away from the halogen 55w units as they are too hot for the housing.
Good Luck
Dale W
/ Brighter Light #6
I found 50W bulbs at the local Fleet Farm store, they were replacement bulbs for fog lights, as I remember they were about $3.50 a pair but what a difference, ran them for allmost a year now with no heat problems to the housings.
2022 EZ-GO ELITE...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
2000 Caterpillar V300B 30,000lb Rough Terrain Forklift (A64553)
2000 Caterpillar...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
