Brighter Headlights for B2150 HSD
/ Brighter Headlights for B2150 HSD #1
Kub
Mason-Dixon Line
Kubota B2150HSD, L3410GST, L35TLB, M5030SUMDT and M108SHDC2
I would like to increase the headlight bulbs in my B2150 to 25 or 35 watt range, replacing the 12v 15/15w originals. The original bulbs seem to be a rare type and not easily located locally. Can someone please help me find this type bulb in the 25 watt range in either a Kubota part or other source? Tnx.
Kub
/ Brighter Headlights for B2150 HSD #2
If you could post a picture of the bulb and / or a part number that is found on the bulb, it would make it easier to know what would interchange. Today, there are so many different type of bulb mounting sockets, it is hard to tell with out some more information......
/ Brighter Headlights for B2150 HSD #3
Take one of the bulbs down to your local Auto-Zone. I bet they have it, and in a higher wattage.
/ Brighter Headlights for B2150 HSD #4
You find that the larger wattage (35) will create to much heat. Which may melt the plastic in the light housing.
My B2910 came with 23 watt bulbs. I put 50 watt bulbs that I bought at Auto Zone. They were in a package for Blazer lights. When I asked at the counter no one knew anything about them.
Attached is a picture of the bulbs that I have. The one on the right is 23 watts. Left is 50 watt.
/ Brighter Headlights for B2150 HSD #5
Ron,
Did you find that the 50 watt bulbs created too much heat in the housing of your B2910 ? If not, it sounds like a cheap upgrade I might want to make.
I'm enclosing a picture of my 15w bulb. There is something printed on the base besides the wattage but I can't read it. I would prefer a 25 watt bulb or even the 23 watt from the 2910 but mine uses a different type bulb. 15 watts is very poor for a headlight. Thanks again.
Kub
I had already checked Autozone without any luck but thanks for the help anyway.
Kub
I would be happy with 23w 25w or even 27w. I don't think they would melt the lens but who knows. Many people have jumped to 50 watts with different tractor models without a meltdown, but I'm willing to stay on the safe side. Thanks for your advice.
Kub
/ Brighter Headlights for B2150 HSD #9
The 50 watt lights did not cause any problems. I put a set of 35 W Halogen bulbs in. They started to melt their own plastic adapters.
Took them out before any damage was done to the headlight housing.
I have the original 23 watt bulbs back in the headlights since I have installed lights on FROP's.
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A64194)
1987 Polar 307 SS...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
