Briggs & Stratton not charging
/ Briggs & Stratton not charging #1
dgla
Gainesville, FL
Dixon SpeedZTR
My Briggs & Stratton Intek 14.5 HP mower engine quit charging the battery. What should I check at the engine?
/ Briggs & Stratton not charging #2
/ Briggs & Stratton not charging #3
Welcome to TBN!
So the voltage when running is less than 14.5V? Replaced the battery too I presume? A bad battery will not accept a charge.
If you can jump start and get 14.5 V or 15V when running then its likely the battery not accepting the charge.
If all this checks out then there is a diode I beleive with spade connections in the charging circuit you might want to check - they allow current one way to the battery - but this deeper into electrical circuits that will depend on your specific unit.
Dead/bad battery cell is my guess.
Carl
/ Briggs & Stratton not charging #4
http://www.tractorbynet.com/forums/craftsman-sears/213135-fixing-my-wifes-new-yard.html
Here's a link to my alternator/regulator replacement.
Check the obvious. Battery cables, ground connections. Then, you'll likely face what I did last summer. Actually, the job was enjoyable and simply not that difficult, if you enjoy mechanic work.
BP - Thats a great write up! My one neighbor brought home a Craftsman DYT4000 last summer - sorta running - adjusted the valves, cleaned it up and sharpened the blades adjusted the deck and it works great- its a B&S 24HP twin with 46" deck.
Another neighbor has a B&S 17.5 HP single cylinder which last spring wouldnt start / crank - found the valves at .012 - .018 so adjusted and then would run for 20 min and stop - found a plugged fuel cap vent! Darn - that one had me stumped for a bit ..
Anyway, same neighbor with 17.5 B&S cant get it running again this week - so I get it going with my 100AMP starting charger, he cuts his grass for 30 min and unit still wont start - bad cell in the battery. When I check his running voltage its 15.9 V which I think is perfect..
I guess my question is what drove you to replace the stator winding - was there no output voltage?
Thanks
Carl
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
KMC 3386 (A64119)
KMC 3386 (A64119)
2019 CRUISE CAR INC ENCLOSED UTILITY CARGO CAR (A59912)
2019 CRUISE CAR...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
