Briggs L head twins
/ Briggs L head twins #1
js5020
Platinum Member
NE PA
Kioti CX2510, Kubota BX23S, AC5020, JDx300R
Maybe this is a crazy question, but I have a couple of B+S twin cyl vertical engines and I was looking and wondering if they could be changed to horizontal if the base and side cover were swaped. Has anyone done this, anything need to be changed inside the engine if it is possible? I realize the intake and muffler would need to be changed. I have found a few heavy duty garden tractors with blown 16 - 20 hp engines that can be had right and I have a sweet runnin 18 if I can get the shaft pointed in the right direction.
/ Briggs L head twins #2
The blocks are the same for the Side and Down shaft engines.
you will need-
Proper base (back cover now) with bolt holes, and sump
Rods or Rod caps with slingers on them
Any other Oil distribution parts, such as a flapper.
Muffler, and pipes
Intake manifold, Carb, air filter box, any governor rods
Ive seen it done...takes a long long time to round up parts and stuff...
Not really all that worth it IMHO.
Thanks MT, I didn't mention I do have a horizontal donor that is complete but the previous owner ran it out of oil so internally it's junk, so I have all the parts and with winter approaching also the time.
T/A Drop Deck Equipment Tailer (A64556)
T/A Drop Deck...
JOHN DEERE 5085E TRACTOR (A64277)
JOHN DEERE 5085E...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
