Briggs head slightly wider than previous???
   / Briggs head slightly wider than previous??? #1
JimS
Have a craftsman riding mower with Briggs engine 31P777-0348-E1. Parts book says head is 796026. When I got it the fins are about 1/2" longer on the exhaust side so the cooling shroud doesn't fit. What's the deal? I ran across several reviews that say its bigger. One person even trimmed the fins off. I noticed some bracing in the push rod area and thought, Great, they fixed some of the issues but cooling is an issue on these engines and I am concerned about the shroud fit.
   / Briggs head slightly wider than previous??? #2
Yes. The replacement tin comes in the box. If the tin isn't in the box, you can still fit the old tin . It will tuck under the shroud yet.
The tin with the new head only covers the bottom and exhaust side of the cylinder. The original covered the intake side also. Should I leave the one side open?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2108 (A58376)
2108 (A58376)
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
SKID STEER ATTACHMENT MULCHER (A58216)
SKID STEER...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2016 John Deere 35G (A55272)
2016 John Deere...
