Briggs head slightly wider than previous???
   / Briggs head slightly wider than previous??? #1
JimS
Have a craftsman riding mower with Briggs engine 31P777-0348-E1. Parts book says head is 796026. When I got it the fins are about 1/2" longer on the exhaust side so the cooling shroud doesn't fit. What's the deal? I ran across several reviews that say its bigger. One person even trimmed the fins off. I noticed some bracing in the push rod area and thought, Great, they fixed some of the issues but cooling is an issue on these engines and I am concerned about the shroud fit.
   / Briggs head slightly wider than previous??? #2
Yes. The replacement tin comes in the box. If the tin isn't in the box, you can still fit the old tin . It will tuck under the shroud yet.
The tin with the new head only covers the bottom and exhaust side of the cylinder. The original covered the intake side also. Should I leave the one side open?
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2008 Genie GTH-844 Telehandler (A57453)
2008 Genie GTH-844...
2005 CAT D6N XL Crawler Dozer w/ 6 Way Blade (A59213)
2005 CAT D6N XL...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Crane Mechanics Truck (A56858)
2015 Ford F-750...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
