Briggs engine repair or replace
/ Briggs engine repair or replace #11
If you decide to remove the carb you should remove the carb and tank as an assembly from the engine first then take off the carb. Pay close attention to the governor linkage and governor spring under the tank. Do not remove or loosen the bolt securing the governor arm to the governor shaft.
Thanks for the answers and suggestions of the problem. Spark always was good engine clean and always carb.problem .
Under warrenty several repairs and carb. kits were put in then the foam put in tank to stop splashing dissolved from the new type fuel and the tubes jets were replaced. the fuel pump on side of carb was replaced by the kits.
when rear of tiller was lifted to remove a rock or stick cought in rear tines fuel would pour out around filter and so over choke and end of work until evaporating fuel then start and maybe in 10 feet engine would be acting up again.
Went 60 miles to TSC. looked at there cub cadet type roto tiller and they used a Honda engine. 5 h-p and GC190 bolt sizing same so purchased and removed the Briggs and installed the Honda. Cost $265.00 and got the 3 year warrenty .
And roto tilled the whole garden with out a problem.
So never found out what was wrong but I have quit looking.
Now to get back to a retirement life.
ken
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
Hay King 12' Pasture Renovator (A60462)
Hay King 12'...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2024 Linx 6'x14' Trailer (A60462)
2024 Linx 6'x14'...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
