Briggs and Statton Backfires through carb
   / Briggs and Statton Backfires through carb #1
Florida
Allmand TLB 325
I have a 445677 0476 E1 Briggs Eng on a Husqvarna lawn tractor. Ran fine shut it down and the next day when I tried to start it it backfires through the carburetor. I checked the coils for spark, checked flywheel key all ok. I took carburetor apart and cleaned it. Still backfires. My next thought is valves, but what has me baffled is it ran fine the day before. Anybody have any suggestions?
I pulled the fly wheel to check it. Thank you for your help
   / Briggs and Statton Backfires through carb #4
I would remove the valve covers and check to make sure all the push rods are still in place, and also check valve clearances. If you find a bent push rod then look closely at the corresponding valve because the biggest cause of bent push rods on that style engine is overheating of the head due to debris buildup on the cooling fins and the valve guide will migrate outward the valve caps until the valve can't open causing push rod failure. And in the event of a missing push rod the rod had migrated through the oil passage hole in the head into the crankcase.
Also if you didn't properly torque the flywheel after removal while checking the flywheel key it could of sheared on start attempt.
   / Briggs and Statton Backfires through carb #5
I have a stand-by briggs generator w/ a Vangard v twin did the same thing. Drove me crazy. Carefully...check valve adjustment. If OK then replace BOTH ignition coils. Yeah I know you checked. I did too and it ran like sh*t backfiring a million times. Changed out both coils and now runs like its brand new.
Thanks for your reply. This Eng is driving me crazy. I have spark on both ignition coils but on a 20k scale I get a reading of 4.90 going from the sparkplug wire and the ground terminal. I don't think I should have a reading. The coils might be the problem because the lawn tractor was working fine the day before and the next day is when I started having this problem.
   / Briggs and Statton Backfires through carb #7
Mine is propane and started backfiring out of the blue also. Briggs answer to backfiring was to check / adj valves. I did that and fooled with the carb but I knew it had to be timing related. I had both sides showing spark but apparently when those coils get crusty, the don't fire like they should. Mine were original likely 15+ years which is way too old when it sits outside all day.
I guess my next step is to check the valves but what is so confusing is this happened suddenly overnight. Thats why I though it was fuel or electrical related
I should have a reading on my coil going from the spark plug wire to the ground.
2013 John Deere 8235R (A53314)
2013 John Deere...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
New Skidloader Stump Grapple Bucket (A50775)
New Skidloader...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
