Brick oven
   / Brick oven #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I was told to start on the end to get everybody's attention. Following that advice, this is the output of a project. We are baking:
Pizza:
Czech rye bread:
   / Brick oven
This is not how it started, but it is the oldest picture I could find.
Building the base, using leftover blocks and parts of a chimney:
   / Brick oven #4
Very nice work.:D :D :D
Now for some "Rox" Olive oil to go with the bread!:D
Secrete skills learned in the Old Country, yes???:D :D :D
   / Brick oven #5
I really love the concrete dome! Looks great, functional and I can taste that bread from here:D
Podunk
   / Brick oven #6
I have a copy of "The Bread Builders: Hearth Loaves and Masonary Ovens" by Daniel Wing and Alan Scott at the top of my reading list. Did you use a set of plans or go with your own design?
Don't suppose you would like to take a little trip to southern Indiana and build one for me...
Great job!
   / Brick oven
Ready for rebar and bottom insulation:
I was not sure if the insulation is going to work, but I done it anyway. The logic was the dome will be standing on the sides and middle supports only a layer of firebricks and the concrete is about 2.5" thick above the fiberglass.
Base is finished:
   / Brick oven
I used regular firebricks and mixture of fireclay (from Indiana:)) cement and sand. That stuff smells like a pond mud and it is very sticky. If you keep bricks dry, they hold in place without support almost all the way to the top. The wooden shapes are needed to follow the arch.
The top looked like a hedgehog with bricks sticking up in the air:
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
17101 (A55787)
17101 (A55787)
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
202476 (A54757)
202476 (A54757)
