Breather Cap Question
/ Breather Cap Question #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
I've never been very happy with the quality of the PT hydraulic oil breather cap. I'm concerned this cap could let in too much contamination (particularly water contamination). Anyone know of a better breather cap (the ¼ turn variety)? I know there are some good threaded caps available. However, retrofitting one of those looks to be more trouble than I would like.
/ Breather Cap Question #2
<font color="green"> I've never been very happy with the quality of the PT hydraulic oil breather cap. I'm concerned this cap could let in too much contamination (particularly water contamination). Anyone know of a better breather cap (the ¼ turn variety)? </font>
As part of the fire damage rebuild of my 1845 I upgraded the cap to a Parker with a 10 micron filter. It doesn't address the water contamination issue but I figured it was a major upgrade over the unfiltered cap PT uses. To mount it I had to machine the old neck off the reservoir cover and drill and tap new bolt holes for the cap mount.
Sedgewood
That sounds like a nice modification. PT now uses a filtered cap on their larger machines. I’ll call them Monday and see if the new caps will fit older tractors.
/ Breather Cap Question #4
Anyone ever clean or disassemble their breather cap to clean it?
If so, any tips?
All the best,
Peter
/ Breather Cap Question #5
WOW! 19 year old thread revival, yet still pertinent information. (y)
Gongrats! I think that make you the current front runner in the ‘deep search’ contest. ;)
/ Breather Cap Question #6
I did think about starting a new one, but this seemed on topic.
So....Have you ever cleaned yours? :)
All the best,
Peter
/ Breather Cap Question #9
I was thinking after fifteen years, perhaps it should get cleaned.
Mine is a plastic cap with a dipstick with some sort of coarse weave 3D plastic strings, like the material that you see around pools or in building entryway to trap/scrub dirt from shoes. (3M Nomad?)
like this stuff;
/ Breather Cap Question #11
Well, I seem to have not succeeded. I tried spraying it out/off with brake cleaner, soaking the top in acetone, sloshing it around, and blowing it out with clean compressed air (a fair amount of oil came off, but not much of the dirt). If nobody knows how to disassemble it, I'm inclined to think that an ultrasonic cleaner cleaner would be the way to go.
All the best,
Peter
/ Breather Cap Question #12
Your guys caps don’t leak? When I am up steep at a side angle I would think the tank would leak with that type of cap
/ Breather Cap Question #13
Not so far...then again, I wimp out at 30ish degrees, at which point I am not moving quickly. I have hit too many rocks and gopher holes at 30 degrees that become 35 in an instant.
What do you use for a cap?
All the best,
Peter
2025 Wolverine QC4-26-15.7G 3-Point Hitch Attachment (A66734)
2025 Wolverine...
1999 INTERNATIONAL 2674 T/A DUMP TRUCK (A67714)
1999 INTERNATIONAL...
2024 JCB 270T Compact Track Loader Skid Steer (A66734)
2024 JCB 270T...
2011 GMC SIERRA 2500HD (A67714)
2011 GMC SIERRA...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
3143 (A63117)
3143 (A63117)
