"Breakout force" (yet another question on this)
   / "Breakout force" (yet another question on this) #11
Well, it isn't that. Boom cylinders give the force called out one line above in the specs. All three of the force specs are:
Lift capacity to maximum height @ pivot pin 726.0 kg (1600.6 lb)
Breakout force @ pivot pin 1196.0 kg (2636.7 lb)
Bucket rollback force at ground level 1234.0 kg (2720.5 lb)
There is a whole lot of stuff in the manual I could have posted.
So which cylinders do you think are making the force in line two above? Boom cylinders or bucket cylinders? Both?
I agree boom cylinders for line one.
I also say boom cylinders for line two.
Bucket cylinders for line three
   / "Breakout force" (yet another question on this) #12
That's correct.
rScotty
Oh. I think I see what you mean. Yes, that makes sense. Thanks! Though I'm still trying to make sense of another post, too....
It's purely the lifting force of the loader from the ground (or at the bottom of it's travel which might be slightly below ground level). The loader is strongest at the bottom of it's travel.
Here's the ISO 14397 definition of breakout force:
https://www.iso.org/obp/ui/#iso:std:iso:14397:-2:ed-2:v1:en
maximum sustained upward vertical force, in newtons, generated at a point 100 mm behind the leading edge of the bucket of a loader, or behind the foremost point of the cutting edge for a loader having a bucket with an irregular (pointed, curved, etc.) cutting-edge shape, by a lift or tilt cylinder, with the bottom of the bucket's cutting edge parallel to, and not more than 20 mm above, the ground reference plane
Of course ISO measures it at a different point than "at the pins" because they're ISO, but that's just geometry. (side note: where is 'at the pins' on a SSQA that's permanently fixed on the loader? the plate face?)
Ah, I think I'm getting it. Thank you. This isn't necessarily the maximum possible upward force, because they are constraining that the bucket is slightly elevated with a horizontal bottom, so it's not in contact with the ground anyplace and therefore it's not prying like a claw hammer. But you are allowed to use any combination of loader arm and bucket curl cylinder. They aren't specifying any limitation in cylinder choice. Like you say. Purely the lifting force from slightly above the ground. (Note, though, it can't be from slightly below ground level, it's with 20 mm clearance above the ground.)
NONE of the lines in my manual's spec list is exactly this. I'm guessing the middle line out of the three would come the closest.
   / "Breakout force" (yet another question on this) #15
I think I see your problem. Yes, the rotation of the bucket DOES add fractionally to the pure vertical lift force at the pivot if you actuate both sets of cylinders at once. You are correct in that.
But that's not how the manual's spec list has described it. Look again. By definiing line two to be measured at the pivot point for the bucket, the length of the moment arm for the bucket cylinder forces is reduced to to zero. So the bucket contribution to lift is zero simply because they have defined the bucket out of the boom lifting calculations. We are only left with the vertical component of the lifting forces that are provided by the boom cylinders. Using the specs given - and their own selection of pivot points - the vertical lifting forces are simply the vertical component of the boom cylinder lifting forces around the boom pivots. Everything else goes to zero.
rScotty
It comes down to defining the pivot point. To reiterate....as defined, the bucket forces are zero for boom lift calcs becasuse of where they placed the bucket pivot point and I agree that is valid.
Now I think your question is this: Is it reality to put that pivot point where they did? Well, not completely..... and I think that is what is hanging you up. But it's the simplest way to calculate the forces - and arithmatically it is elegant. It works perfectly well.
If you do want to calculate the contribution of the bucket rotation to the lift, you have to move the bucket calculations to a different pivot point. That way the vertical component of the bucket rotation doesnt become zero. Then simply add the vertical components. By defining the pivot where they have, they have made these other calculations possible and even easily done if needed.
rScotty
rScotty
rScotty
I think I got it. There's an ISO definition of breakout force, and there's a different definition my owner's manual uses. Not the same thing, but probably the numbers are pretty close. And there's yet another force that one could conceivably create, by resting the bucket on the ground and curling it with a prying motion.
I'll tell you what was hanging me up -- seeing "breakout force" defined as the bucket force you can get with the curling cylinders, and in other places seeing "breakout force" defined at the pivot pin, where -- as you point out -- there's no motion when curling. These are two contradictory uses of "breakout force". And, it's funny that the ISO definition isn't EITHER of these two.
   / "Breakout force" (yet another question on this) #17
Yep, I think you are right on the cause of the hang up. There's a lot of various codes and standards out there for manufacturers who either want to use them or has some reason to do so.
Such "Standards" can be contradictory or even political.....no surprise there :)
Looking at that link you posted showing how ISO wrestled with defining breakout force, I gotta say I prefer the way your tractor manufacturer did it.
To me, New Holland made the right choice to define their loader specs using their own in house definition and standard.
enjoyed it,
rScotty
   / "Breakout force" (yet another question on this) #18
I read the ISO spec as measuring the same way you'd measure at the pins- purely the lifting force- except correcting for the load's center of gravity being a ways ahead of the pins. That's how most 3pt lift specs are stated, i.e. 24" past the end of the lift arms or similar. That gives a more realistic measurement, because of course the 3pt implement or load on the loader is not centered at the lift arms or at the loader pins- it's farther out and thus has more leverage on the loader or 3pt, reducing the lift capacity. It's why you'll see companies like Kubota report loader lift capacities at a fixed distance in front of the pins (and I think they also report it at the pins for competitive purposes).
ISO being ISO they made the definition hard to understand and dependent on the depth of the bucket, which would becorrect mechanically if they did it right but confuses the issue. (I've spent a lot of my career both implementing from and writing standards).
Where are the pins on a SSQA loader?
   / "Breakout force" (yet another question on this) #19
LOL, it doesnt matter what force or lift capacity you buy it will never be as much as you want/need at given time - you can read specs and evaluate them all you want but honestly, there are so many other variables that will determine what you can lift and where - the object, the angle of ground, the position of tractor, what kind of surface you are on, i dont look at specs i look at what i know i can do when trying to manipulate what i want to move and where i want/need to move it to. Do i need to scoot it, do i need to lift it 3 feet, do i need to lift a corner of it and rotate it, how much room do i have, is it slick out, is it on concrete, a spec looses it value when you take all those things into consideration. You may have a certain spec but you might not be able to use it nor will it do what you need at the time.
   / "Breakout force" (yet another question on this) #20
The pins are in the same location at the ends of the loader arms. For calculations, think of the the SSQA as being part of the back of the bucket. With SSQA the bucket weighs a little more and the cutting edge of the bucket is a few inches farther from the bucket pivot.
rScotty
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
2017 KALMAR OTTAWA T2 4X2 SPOT TRUCK (A60430)
2017 KALMAR OTTAWA...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
