Breaking into the bank
   / Breaking into the bank #101
Grading.
Did I ever mention I fear/respect what water can do? The first pic shows a road I started behind the garage to access the attic. My vision was to have an upper and lower road, upper for a perimeter road (4-wheelers, bikes, foot path) leading to a future gazebo/firepit, and the lower road for the attic access.
Additionally, I wanted to grade the roads in towards the slope to allow water to wash away from the garage. Grading is complete, exactly to my specs. Wished I would've done it sooner to get some grass down, so I'll have a muddy mess in the spring to deal with.
Frank,
The grade work looks awesome! What did you use to do the grading?
Obed
   / Breaking into the bank #102
Frank,
The garage looks great. I believe you can be proud of it. I'm curious about the j-channel at the bottom of the siding.
It appears that any rain that hits that wall will all run down the j-channel and exit the j-channel at the front corner of the garage. Can that water run get behind the corner trim piece and up against any of your framing? If so, you might consider putting a piece of flashing to route the water to the outside.
Obed
Beautiful job on the siding Scout! Everything you've done looks great and top-quality throughout!:thumbsup::thumbsup:
Thanks a lot T/A.
I've been very lucky with my subs. My BIL is EXTREMELY picky to the point of obsessive when it comes to choosing subs. He had a pole barn built and took probably 6 months designing the bldg and choosing the concrete sub. So I talked to the sub he chose and liked him, and having already seen his work, and his agreeing to discount the job for cash, it was an easy choice. I did get some other bids but they were even higher and didn't quite hit it off as well.
So my concrete sub did the garage floor, front sidewalk, rear patio, and some other jobs. When I asked him about block guys for the garage walls, he immediately mentioned my #2 sub, the block guy.....and stated he could also build the entire garage if asked.
After talking to the the 2nd guy, I felt pretty confident in his abilities. We agreed on a lower cash price (trying to do the entire garage with cash) and he's been with me ever since, doing the waterproofing, setting trusses, facia, soffet, siding, power, plumbing, everything. I'm doing as much as I can, and we often work together on various tasks.
Since I'm back at work overseas, I've given him the "bang" list to get accomplished while I'm gone.
An example of his attention to detail;
If you look at the pics of the siding on the side walls, you'll see the angle setting back into the bank up the wall of the garage. This matches the stepback angle of the landscape blocks when the wall gets laid up against the building. I thought that was pretty good!
Having good subs makes ALL the difference!
Seems like it would have been a good excuse, err... reason, to get a set of 3pt forks.:D
Never really thought about a set of 3-pt forks. I have a set of front forks, as well as bucket forks.....the front forks takes 1 hour to install. So, I figured I could've moved all the blocks quicker using the loader than switching to forks and switching back to bucket when I finished....I've been using the bucket quite a bit moving material. As for the bucket forks, I've already bent 1 bucket using them, and bent my set of forks....and they're medium-duty.
However, I did use them after I offloaded several courses of block to move 3 pallets of block. Saved myself some work anyways!
Frank,
Obed
Obed -
As luck would have it, my concrete sub does some great dozer work. He did in 6 hours what would have taken me a full week. Not to mention he has no fear of slopes, and I HATE operating on slopes with equipment.....at one point he was dozing sideways up a slope and started slipping sideways down the slope....never bother him a bit. And, he's a young guy, 28....does everything by eye. Very Very talented!
Frank,
Obed
Obed -
Thanks for pointing that out! The siding was started right as I was leaving for overseas, so I will definitely check it out when I return.
Frank
   / Breaking into the bank #107
Beautiful job. Agree about the subs. It works both ways too, you get a better job when you're a good guy to work for, and you're obviously that. Curious as to how he attached the siding to the block sidewalls.. treated plywood with tap-cons? Happy Thanksgiving.
   / Breaking into the bank #108
It looked like the pallets would be too heavy for front forks which was why I mentioned 3pt forks. I always hate having to break pallets open before I'm ready to use whatever is on them. Whatever it is always seems to get damaged after the pallets have been opened.:(
   / Breaking into the bank #109
Obed -
I've always heard that any good dozer operator is born with a bubble up his rear.:laughing:
   / Breaking into the bank #110
The guy who built our driveway used a highlift to do the grading. I was amazed that he could form the dirt so well without a blade that can tilt left or right. He said that when he first bought the highlift, he was having a tough time getting the hang of it. Then he talked to an oldtimer who told him operate the machine with his butt cheeks. What he meant was, use your butt checks to feel whether the machine is leaning to the right or to the left and how much. With that advise, my excavator was able to learn how to do gradework with his highlift.
Obed
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
UNUSED FUTURE MINI EXCAVATOR AUGER SET (A51244)
UNUSED FUTURE MINI...
2018 Dodge Journey SUV (A50324)
2018 Dodge Journey...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2016 Wilson Hopper Bottom Trailer (A50514)
2016 Wilson Hopper...
